Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-14-2008, 10:06 PM
aurgathor aurgathor is offline
Garage is empty, add now
aurgathor is gaining momentum as a positive member of FTE.
Smokey-Yunick engine
(nothing to do with ethanol)
Quote:
many years ago, Smokey took the Rabbit (IIRR) to an EPA test center for initial evaluation on both smog & mpg- it was televised and the the initial 5 minute session calc'd out at 80+ mpg-
People should read: http://en.wikipedia.org/wiki/Smokey_Yunick#Automobile_racing a few things about his cheats.
Quote:
In today's modern vehicles, we are lucky if the 25% of the fuel burns complete...
That is plain BS and misinformation -- in a well adjusted engine, that should be well over 80%.
As for the S-Y engine, it looks good on paper and it's specs are not outright impossible like many other well known "inventions" such as the 200 mpg carburator; however, it still sounds a bit too good to be true.
If it were indeed as good as claimed, automakers would've licensed it a long time ago, unless he were asking some insane amount of money.
Quote:
Some examples & facts (verifiyable)
93-94% of our oil is imported (see BP state of the company report 2006)
Again, completely wrong: http://www.csmonitor.com/2005/0505/p01s04-usfp.html
And I'll skip the rest of your 'facts'....
  #2 (permalink)
Old 02-15-2008, 10:35 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
More like 99 percent of the fuel burns completely, with the cat taking care of the rest. Maybe he meant 25 percent thermal efficiency, which is close to being correct. The problem is that the theoretical maximum is only about 35 percent for an otto cycle internal combustion engine.
A five minute test at 80mpg proves nothing. I once got 100mpg (as shown on the trip computer) in a rented Cadillac, coasting downhill.
  #3 (permalink)
Old 02-15-2008, 03:12 PM
I may have been a bit conservative with "well over 80%", but also, I didn't include what is burned in the CAT because that normally goes to waste.
I know he may have meant thermal efficiency, but since he quoted 2 very different numbers in the same paragraph, one of them is gotta be very wrong.
Quote:
In today's modern vehicles, we are lucky if the 25% of the fuel burns complete...incomplete combustion produces by-products (ie polution). Smokey took an impellor (similar to a turbo) and placed it iinbetween the manifold & carb., heating the fuel to about 400 degrees and by swirling the air/fuel at high speed together, vaporized (almost) the fuel. As the mix entered the combustion chamber, 90%+ of the fuel burned= almost no polution and lots of HP.
However smart and resourceful he was, the laws of physics apply to everyone with no exception. And because of all the trickery he had done on NASCAR cars, I don't find it unbelievable that there were some cheats behind those mpg numbers.
Based on a quick look, it appears he's trying to scavange some of the waste heat, and that's not what I think would be an adiabatic engine. Adiabatic engines are simply engines with little or no additional cooling, but because of the high temperatures, they present some serious engineering challenges. In addition, they're also very bad about NOx emission.
  #4 (permalink)
Old 02-24-2008, 02:06 PM
monckywrench monckywrench is offline
monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.
"If it were indeed as good as claimed, automakers would've licensed it a long time ago, unless he were asking some insane amount of money."
Anyone wishing to read about it, including patents, and copy it for personal use could do so to verify it works.
  #5 (permalink)
Old 02-24-2008, 09:54 PM
I don't doubt that it works. What I don't believe is the specs -- it's just to good to be true. Making an engine that gets over 1 HP/CID is not that difficult, same for a low emission. Making one that is significantly more efficient than what we have today, however, is much harder, but for the argument's sake, let assume it's possible. But making one that does all three? I can't say it's impossible, but it's definitely non-trivial. Given CAFE and the current fuel prices, it would make no sense to not use it, if it would work as well as claimed.
Tags
100, 80, 80mpg, chamber, combustion, diesel, engine, ford, mpg, smokey, smokeys, swirl, yunick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
