U1262 Code - Ford Truck Enthusiasts Forums
U1262 Code
Old 02-14-2008, 09:24 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
U1262 Code
Hi all. I am working on an 03 f-150 supercab two wheel drive 5.4 z code engine, automatic. It is a LP GAS truck. The compuvalve failed, and we are not going to repair it. We now have 3 bad valves on other trucks and they are going to be phased out, due to cost and maintence. I have a code u1262 that wont go away. I have looked at wires till i am blind. I did find two that were rubbed through, and shorting on the A/C drier, just under the starter solinoid behind a metal bracket that two big gray wire conectors clip onto. I repaired them. I also removed all the lp gas wiring, and plugged the factory harness connectors back. I no longer have a code for the throttle position sensor, or tp circut. I no longer have a code for the 02 sensors. I think there were 6 or 8 codes, that i think were because they are tied to the compuvalve. The u1262 will only set when you turn the truck off then restart it. As long as you dont turn the truck off, it will not set. Any ideas
Thanks Dave P
Old 02-14-2008, 11:49 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Dash common Bus fault, instr. cluster.
Old 02-15-2008, 06:08 PM
Thank you Bluegrass 7. I have another one that the odomiter flashes now and then, but i have not touched it yet, might next week. Thanks for the input. I will keep you posted if i find anything.
Dave P
Really need Help and guidance. S.j. Price 1997 - 2003 F150 7 03-28-2015 02:46 PM
Big Propane Problem Please Help FordProTrucks Alternative Fuels, Hybrids & Mileage 9 01-12-2012 05:52 PM
help 2000 ex running like crap jeffvitt 1999 - 2003 7.3L Power Stroke Diesel 13 04-06-2011 11:08 PM
Removing compuvalve from bi-fuel to run on just gas bsparks72 Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 05-18-2010 08:14 PM
died + no start / NOT CPS / recurring code U1262 Justin03PSD 1999 - 2003 7.3L Power Stroke Diesel 13 05-27-2009 01:33 PM
Tags
2000, 2003, 2004, 60, code, diesel, error, expedition, explorer, f150, ford, ls, navigator, ranger, u1262
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
