Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2008, 08:10 PM
Dieselguy89 is starting off with a positive reputation.
Is it possible to make the wheels turn sharper on a 92 supercab long box
How Is it possible to turn up the turning radius on my 92 f250 supercab longbox I have the heaver frontend does that effect it ?
Hate having the wheels not turn sharp enough. The truck has stock wheels and tires size. I think some one has had 33's or bigger tires on it one time
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-14-2008, 09:14 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
You can try to adjust steering stops in a little bit (I can't remember how they are set up on a F250). But you want to be be careful not to adjust them too much. You can cause the front axle u joints to bind with the hubs locked and cause a steering issue. Or in 4wd, you can break axles, u joints etc.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 02-15-2008, 09:12 AM
knash0727's Avatar
knash0727 is starting off with a positive reputation.
Just be glad it aint a chevy. My 85 F250 will turn circles around my friend's S-10.
__________________
Kyle J. Nash
Proudest member of the
FIGHTIN' TEXAS AGGIE CLASS OF 2011!
85 F250 6.9L Diesel Standard cab 4x2 LWB
74 F100 6.4L 390 Standard cab 4x2 LWB
  #4 (permalink)
Old 02-15-2008, 10:22 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
I have the same problem!! I can't figure out why mine wont turn on a dime or even a half dollar. I block 4 lanes of traffic just trying to pop a u and people run when I park next to them. Ya, mine will turn circles....around texas. I wouldn't even be able to touch an s-10.. I think even some semi's can turn tighter than me. Any solutions would be absolutly wonderful. (if there are any)
!---------------------------------------------------------------! over 23ft! Surely this ain't the problem.
Yall have a great day.
  #5 (permalink)
Old 02-16-2008, 03:40 AM
prestroke diesel is starting off with a positive reputation.
well you could buy more land to turn it around on...
  #6 (permalink)
Old 02-16-2008, 10:06 AM
Olytlr is starting off with a positive reputation.
I just got a '87 F250 supercab longbed 4x4. My thoughts are that the turning radius is directly related to the front leaf spring suspension. I would figure the wheels can only turn in as far until they would come in contact with the leaf springs. I may be totally wrong but this is my thinking.
  #7 (permalink)
Old 02-16-2008, 02:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Spring to tire clearance when turning will be the limiting factor.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 02-16-2008, 03:08 PM
Is there bigger spings in our newer trucks or because its a supercab,
My 78 f250 regcab longbox turns on a dime evan with 33's on it and no lift, or bodylift
  #9 (permalink)
Old 02-16-2008, 04:41 PM
I would assume your 78 also has front leaf springs. The extra length of the supercab obviously doesn't help but do you have aftermarket wheels on your 78? Wheel offset can make a little difference.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
