Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2008, 07:35 PM
Sawsall is starting off with a positive reputation.
long arm & air instead of leafs...
I have the body off the 79 frame... getting ready to clean it up, paint & re-seal the motor up...
Since I have to move the rearend forward 3 inches to match the 66 body, I was thinking how easy it would be to move the front spring mount further forward and fabricate long arms and bolt it to the spring perch on the rearend... make a panard bar & mounts... and airbag it...
your thoughts welcome...
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-16-2008, 12:01 PM
Texas Jim is starting off with a positive reputation.
saw,
Whynot just have new main leafs made. At a spring shop, they're easy to make,not very expensive. This way you can get whatever length you need and even get the eye reversed inorder to drop it lower w/ your air bags.
  #3 (permalink)
Old 02-16-2008, 03:45 PM
Yep, I thought of that... Just something I thought of, and bring the suspenstion out of the horse & carraige age...
This is wierd, I thought I posted this, but came back & didn't see it so I reposted... now there is 2 posts.
  #4 (permalink)
Old 02-17-2008, 01:25 AM
garbz2 is gaining momentum as a positive member of FTE.garbz2 is gaining momentum as a positive member of FTE.
I am using a two link and center long bar suspension with Bilstien Coil overs in my Uni.
The shorter you keep the bars the better off the handling will be with torque loading an twist. Bags need all the help they can get in this area. Also use a good set of shocks for dampening. Bilstiens will be the best measured to fit.
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive DOHC, EOD.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
