I recently got both my headgaskets replaced along with the addition of a new camshaft and headers. I have had the truck back for about 3 days now, but when I start the truck up, theres this sound of swooshy water coming through the dash, now I assume thats the sound of the coolant circulating in the water jacket ect, but my only concern was i have never heard that noise before prior to the big project. Is this the sound of low coolant in the system, or just air pockets that will eventually bleed themselves out?
__________________ 95 F350 w460 Big Block:E4OD transmission,K&N Intake,Performance Camshaft, Ceramic Coated Doug Thorley Tri-Y headers, 2 1/2" true dual exhaust w/ Cherry Bomb Extreme's & gutted cats,22" x 4" SS tips. Limo tint,black paintjob, rollpan, smoked lenses and LED's all around, HID's, American racing rims with Pirelli Scorpion ATR tires. 0-60 6 seconds.
it is air/coolant mixture in your heater core.
i bet the heater hoses were installed reversed.
there is an inlet and outlet to the heater core, and if the hoses are reversed, sometimes the coolant will not properly fill the core, resulting in the flowing water/gurgling sound you are describing.
__________________
Join me in the New Jersey Chapter, CLICK HERE!
should that be addressed ASAP? Also, the truck now wont shift past 2nd gear with the help of me assiting manually into 2nd, how do i reset the computer for all the new mods?
Park on a hill with the front up so that the rad. cap is the highest point in the cooling system. Start with engine cold and rad. cap off and heater full on. Observe rad. neck while engine warms up. This will burp out trapped air. You will need to add more coolant as the level goes down. Hope this helps.
