Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2008, 10:19 AM
BadHabitinVA is starting off with a positive reputation.
Intersting info on the 5.4L upgrade
The gentleman that wrote this article seems to be in the know quite often and posts at another board.
http://www.autosavant.net/2008/02/de...gt-engine.html
Quote:
Throughout Ford, the V8 lineup is undergoing a significant makeover. With the debut of the 2009 F-150, Ford released a new version of the 5.4l Modular (also called MOD or Triton) V8. This new engine, while sharing many components with earlier models, will sport meaningful improvements in horsepower, torque, and fuel mileage. This update will position the engine’s torque in the neighborhood of much larger V8 engines, such as Toyota’s 5.7l iForce, or GM’s 6.0l Vortec Max. The new 5.4l will see only truck duty, however.
Later this year, Ford will also finally release the BOSS V8 engine, and once again this engine will be truck-only. The engine will be a 6.2l SOHC V8 with an expected 425hp and 450 ft.lbs of torque. The first vehicle with this new engine is to be the 2009 Navigator, the one vehicle in Ford’s lineup that desperately and unquestionably needs the engine. Around the end of 2008, this engine will finally make it to the F-150, and maybe even the Expedition.
__________________
'04 SuperDuty Beast
  #2 (permalink)
Old 02-14-2008, 10:46 AM
fordtruckman's Avatar
fordtruckman is gaining momentum as a positive member of FTE.
350hp, 365ft/lb thats my guess, anyone else?
__________________
Matt / Michigan Chapter Member
2004.5 F150 STX, 4x4, 4.6l, Scab / Click Picture
2007 Ford Fusion SEL V6
  #3 (permalink)
Old 02-14-2008, 11:18 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD is starting off with a positive reputation.
im guessing 350/400.... hell with my edge and intake i should be around 390ft/lb at the crank... thats only 25ft/lb which is what most tuners offer...so i would hope that they would make at least that
__________________
99' F-150 Super Cab Step Side
5.4l/4R70W (previously a 4.6l romeo)
Cold Air Kit
Flowmaster 50 series dual exhaust
Edge w/Attitude Programmer
900LB add a leaf rear springs
Lariet LE leather front captains chairs
Alpine cd player
Alpine 6x9 3 way speakers (all 4 doors)
10" L7 Kicker Sub
1400 watt Lanzar dual channel amp.
32" Micky Thompson MTZ's
  #4 (permalink)
Old 02-14-2008, 01:08 PM
Big Bad is gaining momentum as a positive member of FTE.Big Bad is gaining momentum as a positive member of FTE.
320 hp, 380 lb.-ft is my guess. Notice the article said the upgrades will position the engine's torque in the neighborhood of it's larger compeitors, not it's horsepower.
Toyota 5.7 - 401 lbft (381 hp)
GM 6.0 - 375 lbft (367 hp)
  #5 (permalink)
Old 02-14-2008, 01:37 PM
dascro is starting off with a positive reputation.
I'm guessing around 330 hp 380ft*lb. I'd be quite happy with that also. It would be cool if they could be competetive with the smallest displacement. I hope for fuel economy improvements too!!
  #6 (permalink)
Old 02-14-2008, 02:41 PM
robpar is starting off with a positive reputation.
The consensus seems to be about 380 ft-lbs torque. So using that number and the current specs of 365 lb-ft at 3750 RPM and 300 HP at 5000 RPM at that speed the engine
is making 316 lb-ft of torque. Using these ratios then:
380 ft-lb at 3750 RPM = 270 HP
316/365 x 380 = 329 lb-ft at 5000 RPM = 313 HP.
Now if you can hold that torque to 6000 RPM then you have 375 HP. I'm not sure that power at the engine speed is of much use in a truck, except for bragging rights in drag races. Give me that torque around 3000 RPM where I can do some useful work and I will be happy.
By the way 380 lb-ft of torque is 1.15 lb-ft per cubic inch and that is a very decent number. Full on race engines can make as much as 1.4 to 1.5 lb-ft per inch when on the cam but any streetable engine that make 1.1 to 1.2 lb-ft per inch is doing extremely well.
Bob Parry
  #7 (permalink)
Old 02-14-2008, 03:12 PM
Quote:
Bob Parry
My stock h/c/i/short-block 4.6 4V makes 1.22 lb-ft per cubic inch at the rear wheels, or about 1.38 lb-ft per cubic inch at the flywheel assuming a rather conservative 12% driveline loss. It also gets 23 mpg on the interstate taching ~3,000 rpm, makes 276 lb-ft at 2300 rpm (at the wheels), idles like a Lincoln, and loves to rev. Not too shabby for an engine most people say sucks (n/a Modular).
  #8 (permalink)
Old 02-14-2008, 04:50 PM
builtfordtough13's Avatar
builtfordtough13 is starting off with a positive reputation.
I agree with the 320-330 horsepower estimates and about 380-390 ft. lbs. of torque.
__________________
Jake
Mine: 1994 F-150 4x4 Supercab, 351, E4OD, Light Santa Fe Clearcoat/Medium Polomino Accent 155,000 miles
Dad's: 2004 Expedition Eddie Bauer White/Gold 4x2 Every option except Nav 52,000 miles
Mom's: 2001 Focus SE Sport, 2.0L Zetec Fort Knox Gold 131,000 miles
  #9 (permalink)
Old 02-14-2008, 05:48 PM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
He basically repackaged everything that's already been said, adding nothing new except dressing it up as if there's something actually there.
__________________
Ken Payne
Gone Fishing...
LACK OF PLANNING ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
2006 Roush F150 Project: Roush Supercharger, Troyer & My Tuning, 9lb pulley, Level 10 Trans, E-Fans, Oil Separator, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Headlights & Taillights, Retrax Retractable Tonneau & more.
2004 F250 King Ranch Crewcab 4x4 6.0L PSD project: DP-Tuner Tuning and MBRP Stainless Dual Exhaust.
2000 Ranger Supercab XLT 3.0 V6 project: Bright Box, Mac Intake, Tonneau, my tuning.
RIP: 1967 & 1975 F100, looking for a 66 F100
  #10 (permalink)
Old 02-14-2008, 06:16 PM
boxcar1974's Avatar
V10 = BSEG
boxcar1974 is gaining momentum as a positive member of FTE.
My guess is 1000hp/750ft torque.
I understand the anticipation but when Ford say it I will believe it. Ken has said it before. Ford has told nothing about it. They wont let some internet blogger ruin thier number.
So my guess is nice round numbers.
Alot goes into truck performance than the engine numbers. Tranny and gearing are more important.
I drive a V10 with 3.73 and the so so 4100 tranny. The engine has a ton of torque but struggles getting it tot he ground. My company chevy 5.3L with deeper gears actually has better drivability. The V10 has gobbs of torque but the setup is the weakest of ford offerings. My V10 4.30 DRW dump body is just right. If it was a torqueshift 5 speed tranny it would be perfect.
Give me a 1/2 ton truck with in the 300's in HP and close to 400 in TQ with a nice 5 speed and 4.10-4.30 gears and I am in love. 4.30's are a longshot from the factory but I have 4.10 are not. My dads doge with 3.92 are perfect for his truck. So 4.10 would be even better. Engines run better with abit more RPM in them.
__________________
03' Super Duty, XLT Sport, V10, Auto, Dark Shadow Grey, Banks Powerpack, SVT 18x8 wheels, and Toyo Open Country A/T 285-65-18E
  #11 (permalink)
Old 02-14-2008, 06:17 PM
gui88ford's Avatar
gui88ford is starting off with a positive reputation.
my guess is 365 and 400 for the 5.4 witch is PLENTY
__________________
Pennsylvania Chapter: Enjoying our little part of the world
2007 F150 XLT super cab, chrome package, 18" Chrome Clad Wheels, 5" Step Bar, 3.73 LS, 5.4 FFV 4x4
2002 Harley Davidson V-Rod --to many mods--
2006 Polaris 700CC Sportsman --to many mods--
  #12 (permalink)
Old 02-14-2008, 07:52 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Quote:
It's already at 365lb/ft. That would mean no increase.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #13 (permalink)
Old 02-14-2008, 08:57 PM
REDFORDFX4 is starting off with a positive reputation.
Thumbs up
Quote:
My guess is 375 and 405? That would be good, then I would forget about gettin the diesel!
  #14 (permalink)
Old 02-15-2008, 02:00 PM
dwrestle is starting off with a positive reputation.
If they are just going to drop the 5.4 later why would they spend a bunch of money to give it a huge increase in power like that, when the 6.2 is on the horizon. I wonder if the 4.6 will benifit from these alleged huge increases.
  #15 (permalink)
Old 02-15-2008, 03:22 PM
heathk2003 is starting off with a positive reputation.
I think no matter what the power/torque increase turns out to be, the performance is going to be greatly improved due to the new 6 speed auto. With first gear ratio of 4.17:1 second gear 2.34:1 third gear 1:52:1 fourth 1.14:1 fifth .87:1 and sixth .69:1, i am predicting near tundra levels even if they are 40 hp short!!! I am by no means a ford fan but i am not blind to smart engineering. Way to go ford.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
