Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2008, 11:07 AM
sedly's Avatar
sedly is starting off with a positive reputation.
Spindle Bearing?
What is the best way to remove the spindle bearing?
__________________
Can never seem to stay in the bush long enough!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-14-2008, 11:29 AM
sedly's Avatar
[quote=sedly]What is the best way to remove the spindle bearing?[/QUOTE
Here's a pic.
__________________
  #3 (permalink)
Old 02-14-2008, 12:09 PM
sedly's Avatar
Anyone know how to move this thread to a different forum?I prolly should have posted in the clutch,tranny,axle,dif forum.
__________________
  #4 (permalink)
Old 02-14-2008, 12:10 PM
masterbeavis's Avatar
masterbeavis has a good reputation on FTE.masterbeavis has a good reputation on FTE.masterbeavis has a good reputation on FTE.
If you are not going to re-use it, I would take a brass punch and a hammer to the back side of it. If you want gentle and sentimental, break out one edge, pull the needles, use a dremel tool to grind away the metal, pry the remnants out.
__________________
Tony
Quando omni flunkus moritati - when all else fails, play dead.
If I posted something useful, click the in that post.
  #5 (permalink)
Old 02-14-2008, 12:18 PM
sedly's Avatar
Masterbeavis,alway's with good info as usual.I will use a brass punch to remove it.Do I use the punch to put in the new bearing?I already did the wheel bearing's in this manner,but the spindel is so much longer it may be difficult.
__________________
  #6 (permalink)
Old 02-14-2008, 12:37 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
There used to be a tool available to drive these out really easily. I used to have one but broke it and I wasn't able to find a replacement.
If you can get the right angle to get in there with a punch, that is the easiest way.
If not, I use a lady foot prybar insert the foot on the back of the bearing and then drive it out with another punch.
To drive the new ones in, I use race drivers. But an old socket that is the same diameter as the bearing works good. Invert it so that the square drive end is facing the bearing.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #7 (permalink)
Old 02-14-2008, 12:39 PM
sedly's Avatar
Right on RCrawler.I'm heading to the garage right now,I'll give it a go.Thank's.
__________________
  #8 (permalink)
Old 02-14-2008, 01:10 PM
Goes to show there is more than one way to skin a cat. On the note of using a punch,(steel) I would be VERY careful to not damage the side of the spindle while trying to beat the thing out. Also, a careful dose of heat will loosen things up quite nicely, allowing the bearing to come out alot easier.
__________________
Tony
  #9 (permalink)
Old 02-14-2008, 03:21 PM
RCrawler's Avatar
Yes, if you are using a punch directly, brass is the way to go.
Jason
__________________
  #10 (permalink)
Old 02-14-2008, 09:19 PM
whd507 is starting off with a positive reputation.
mine were rust/welded to the housing. I had to cut them out all mangled. the cast iron spindle is very easily scored, so always err on the side of caution
__________________
1994 Bronco, 1996 Bronco, 1996 E-350, 1979 F-600 Crewcab, 1976 F-150 4x4 4-sp,1976 F-150 Crewcab,1976 F-250CS, 2003 Mercury Marauder and assorted other boring vehicles...
  #11 (permalink)
Old 02-14-2008, 09:29 PM
RCrawler's Avatar
Are you talking about the spindles being stuck in the knuckles?
Jason
__________________
  #12 (permalink)
Old 02-15-2008, 12:49 PM
sedly's Avatar
I got 'em.Everything is done under there now.Thank's fella's.And BTW I used a brass punch.It just so happen's that I live across the street from a machine shop.Very handy.I borrowed a long punch from them.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
