Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2008, 09:15 AM
JSPajak is starting off with a positive reputation.
Locks Frozen
Well, I couldn't get into my 77 F150 this morning. We had rain which turned to snow and it got a little cold (18) last night.
I did finally manage to get the key into the lock cylinder but I couldn't turn it either way.
I remember the lock freezing up similarly in my 68 Fairlane wagon in the past.
All was not lost as I was able to get into the 00 Excursion for the ride to work.
Any ideas other than leaving the truck unlocked?
__________________
John Pajak
Lexington Park, Maryland
61 F100 Unbody: http://i5.photobucket.com/albums/y190/jspajak/61_F100.jpg
77 F150
00 Excursion
http://jspajak.tripod.com
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-14-2008, 09:58 AM
codyingersoll123 is starting off with a positive reputation.
small handheld propane torch on low??? take it easy on the paint though...
I dont know though because Im born and raised here in SWFL where its blue skys and 70's right now....I dont know what cold is...never seen snow...so thats just my 2 cents...its a shot in the dark though
__________________
Cody
1979 F150 Short Box Custom 4x4 351M, NP435 tranny, NP205 T-case and 35x16 Boggers
1995 F150 XLT 4x4 5.0 Reg Cab Long Bed Spooled Up Rear and 34x12.5 Truxus MT's FOR SALE!!!
2001 F150 XL 4.2 V6 (Why did they drop the unbreakable 4.9L???)(Daily Driver)
  #3 (permalink)
Old 02-14-2008, 10:06 AM
kuzzins27's Avatar
kuzzins27 is starting off with a positive reputation.
Um, a 97 cent can of lock de-icer from Walmart? I also use this for my padlocks.
In a bind, heat your key with a lighter and insert it for a couple minutes to thaw the mechanism, repeat until key turns.
__________________
Just because I'm a girl doesn't mean I don't like getting dirty, too!
  #4 (permalink)
Old 02-14-2008, 11:53 AM
IZZYAZ's Avatar
IZZYAZ is starting off with a positive reputation.
Get the lock de-icer. Then when everything is warm and dry, spray in the lock with some silicon spray. Also hit the latch, hinges, etc. I also spray it on a rag and wipe down the weather stripping. Never been iced out of a vehicle since I started doing this.
__________________
Izzy
1974 - F100 4x4 360 C6 - Currently being rebuilt
1970 - Harley Davidson 3-wheel golf cart Rat Rod
  #5 (permalink)
Old 02-14-2008, 12:28 PM
northerndave's Avatar
northerndave is starting off with a positive reputation.
if you are in a pinch & don't have time to fetch a can of lock de-icer.... well I was going to say open a bottle of "hhet" or other brand of gasline antifreeze, hold the neck of the bottle firmly & squarely against the key lock & gently squeeze the bottle until you can feel that it has melted the ice & is starting to take the alcohol. (that's what gasline antifreeze is, isopropyl alcohol) so, if you don't have a bottle of gasline antifreeze either, check the medicine cabinet in the house for a regular bottle of rubbing alcohol. it'll cut through the ice, what spills inside of the door shell will evaporate & what you spill on the outside on the paint will not hurt your paint.
  #6 (permalink)
Old 02-14-2008, 12:38 PM
Mil1ion is starting off with a positive reputation.
In a hurry ?
Just heat the key with a lighter.......insert into lock...let sit for 5-6 seconds.
Reheat key and insert again as many times as it takes attempting to turn it every time.
The heat from the heat will heat the lock.
aside from the lock de-icer..You can also buy a battery operated lock thaw device for $5.00
  #7 (permalink)
Old 02-14-2008, 12:47 PM
forgot about the hot key trick... a classic.
ahh the good ole days.
  #8 (permalink)
Old 02-14-2008, 01:02 PM
m78 m78 is offline
m78 is starting off with a positive reputation.
We get a bit of freezing rain here and it gets down around all the door seals so you couldnt open the door if the key did work.
I've taken the forced air construction style heaters to thaw them out.
__________________
Mark
04 E-350
87 Bronco II
78 F-250 SC/CS
  #9 (permalink)
Old 02-14-2008, 01:05 PM
Canada has tons of In-car heaters for sale in stores to prevent that from happening.
Thing is though ,they have to already be in the car/truck plugged in to the extension cord ready for power 2 hours before you start the vehicle.
  #10 (permalink)
Old 02-14-2008, 01:44 PM
damn near everytime I go to climb into my 77 half ton or my 70 3/4 ton in the winter I have to load test the door handle to get the door open, those froze shut doors really suck.
  #11 (permalink)
Old 02-14-2008, 01:45 PM
m78 m78 is offline
I loaded my E350 van with pressure treated lumber one warm day, which filled the van with humidity. That night the temp dropped and the humidity condensated then froze to everything on the inside.
__________________
Mark
04 E-350
87 Bronco II
78 F-250 SC/CS
  #12 (permalink)
Old 02-14-2008, 11:26 PM
tomcasino's Avatar
tomcasino is starting off with a positive reputation.
This won't help free a frozen lock but it will help lubricate. Graphite can be purchased at any auto store. It comes in a tube and you just squeeze it into the key hole. Makes any kind of lock work nice and smooth.
__________________
'76 F250 4x4 390 C6 203
'75 F250 4x4 390 C6 203
'77 F150 4x2 351M T-18
"Imagination is more important than knowlege"-Albert Einstein
  #13 (permalink)
Old 02-14-2008, 11:38 PM
bucks77ford's Avatar
We will rise again
bucks77ford has a good reputation on FTE.bucks77ford has a good reputation on FTE.
Well, aside from the ideas mentioned, a more expensive way would be to build a heated garage.
On the serious side, the lock deicer works well.
__________________
BUCK
"My mind works like lightning, one brilliant flash and it's gone"
1977 F250 4x4 Highboy-Frame Off Restoration in Progress
  #14 (permalink)
Old 02-14-2008, 11:43 PM
73f100shortbed's Avatar
That's how we roll
73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold
Call in sick from work. Then watch tv till locks thaw.
__________________
Sean
Tim's Minions - Resident BEEFCAKE!
1973 F100: 302, 3-speed, Hurst shifter, headers, dual exhaust
Member of the New Jersey Chapter
For Sale!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
