Reman 4.6 engine - Ford Truck Enthusiasts Forums
Reman 4.6 engine
Old 02-14-2008, 12:23 AM
lennywho lennywho is offline
lennywho is starting off with a positive reputation.
Reman 4.6 engine
Hello. New to the forum and hoping I could get some advice. I have a '98 F150 4.6 Windsor motor, 130k miles, runs great, no smoking, knocking or oil consumption problems. The head gasket(s) are leaking combustion to coolant. I looked at the truck and the book and decided I would prefer to take the extra time to remove the engine and do the job on an engine stand. At first I figured on sending the heads out for a likely resurface, and then replacing gaskets, and maybe timing chain set and lifters for general princable. This is a truck I use and downtime is important. I starting thinking about reman longblocks as a quicker job and if high quality hopefully I can get another 100k out of the engine. Ford has one for about $2900. I spoke to them, they are not done in house but rather by a rebuilder for Ford. I have seen Marshall remans for $2200-$2500., as well as other brands. The money isnt an issue, but I do want the best value for the money. I love the truck, I bought it cheap, I'll probally keep it forever, and I'll save by doing the job myself. So my question is does anyone have any experiance with differant brands of remans, or any other advice. I wont consider a junkyard engine.
Thankyou.
Old 02-14-2008, 06:30 AM
phatpony phatpony is offline
phatpony is gaining momentum as a positive member of FTE.
I wonder...why would you post this in the 2009 forum? You would be better suited posting this where people frequent this subject the most, say the modular engine 4.6 / 5.4 L forums.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
