400 4x4 oil pan
400 4x4 oil pan
Im trying to find a stock replacment oil pan for my 400.
Its a rear sump and all I can find is a front sump.
Milodon does have a rear sump but its @ $300.
I just need a regular old stock pan. I hate to use my old leaky one on a fresh rebuild.
Any advice would be great, Thanks, jjddoogg
400 4x4 oil pan
I see them going on eBay all the time, just keep checking. Otherwise the local scrapyards are your best bet. What is wrong with your pan?
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
400 4x4 oil pan
>My old pan leaks around Where the dipstick screws in. I
>will use it as a last resort. I was just hoping to find one
>in better shape.
Here's a little fix it for your leaking pan.
Get some Brake Clean and wash the whole pan up nice and clean. use the whole can if you have to paying extra attention to the dip stick area after you get it really clean wipe dry whit clean rags, and then blow the dip stick area with compressed air if you got some.Make sure you get all the brake clean out of the fabric gasket. Now get yourself some good Clear silicone and go all around the edge pushing the silicone into the crease. Let set up ...... Your done Good as NEW
>in better shape.
400 4x4 oil pan
are you needing one I have a extra. with the lift my 79 f-250 I run the normal car/ truck pan with no problem (but it is lifted) getting ready to put in another 400 (well maybe) e-MAIL me @ smurfblue3 at excite.com
FORDS always look better when pulling a CHEVY
dano1805
09-09-2021 09:48 AM
mattscot007
12-09-2005 02:22 PM
