Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2008, 12:33 AM
KyleG is starting off with a positive reputation.
Unhappy Turbo not working!
The turbo kit i have for my 6.9 pickup is a bit strange but should still force air into my intake. Its one that bolts straight to the driver's side exhaust manifold, and runs one down pipe(not connected at all to the passenger exhaust manifold)straight down along side of the driver's side manifold. I just hooked everything up over the past few days, and when i fired it up today, the turbo did not spin at all, just a little at high RPM....any thoughts. I need help. Thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-14-2008, 01:30 AM
GenLightening is starting off with a positive reputation.
How easily does to turbine spin? Any pics of the setup?
  #3 (permalink)
Old 02-14-2008, 05:08 AM
fonefiddy is starting off with a positive reputation.
What turbo did You use?
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
  #4 (permalink)
Old 02-14-2008, 09:05 AM
I'll get some pictures for you later on today, but I can spin it good with my finger. It is an older kit made by Turbo Engineering INC, it runs a Rajay turbo. I just set it up and I didnt tie the downpipe into the rest of the exhaust yet.
Should the turbo be spinning at idle? If the turbo bolts on the exhaust manifold, all the exhaust should go through the turbo from the driver's side. Right? There is two outlet flanges on the turbo exhaust manifold, one on top for the turbo and one where the factory exhaust bolts on there should be only one, that is what makes sense to me.
  #5 (permalink)
Old 02-14-2008, 11:46 AM
ghunt's Avatar
ghunt is starting off with a positive reputation.
Yes, it should spin at idle.
So here's a question- your wastegate flapper isn't stuck open, is it? (assuming that's a wastegated turbo)
If it's open, or even just partly open, it'll prevent the turbo from boosting properly.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel
http://www.cardomain.com/ride/3055099
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
http://www.cardomain.com/ride/306349
  #6 (permalink)
Old 02-14-2008, 05:55 PM
Well here is some pictures of the turbo on the truck, and i still cant get it to spool fast enough. It will spin at high rpm but not really at idle, but it is definitly not spinning fast enough.
The turbo bolts right on the manifold.
But it still has the original flange and pipe on the new manifold that came with the turbo, so i connected it back up. But dont I have to block that off or make it smaller so more exhaust goes through the turbo and out the down pipe? As you can see I didnt tie in the down pipe to the original exhaust.
Could a lack of oil flow cause a turbo not to turn fast enough?
  #7 (permalink)
Old 02-14-2008, 06:16 PM
tjc transport's Avatar
find me if you can!!!
tjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant future
how many outlets are on the manifold???
is there only the one going to the turbo, or are there 2, one for the turbo, and one going to the y pipe??
if there are 2 outlets, the turbo will not work, cause it is not getting enough flow to spool properly.
and with it only getting pressure from 4 cylinders, it will not spool very good.
i think of there are 2 outlets on the manifold, you should hook the passenger side to the one that is not connected to the turbo. this will give you full exhaust pressure to spin the turbo, and all exhaust will then go out through the downpipe.
if any of that made sense
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox, all better now!!
  #8 (permalink)
Old 02-14-2008, 06:43 PM
LilDuke's Avatar
He rides the short bus.
LilDuke is starting off with a positive reputation.
Do both of those pipes in the last picture go to the turbo exaust inlet? If so, then I'm gonna go out on a limb and say the other exaust manifold is supposed to get tied into that one. (only take what I say as opinion)
What is this other pipe that came with it. If I am understanding correctly... The turbo bolts onto the left exaust header. There is a pipe from the exaust side of the turbo that goes down to the exaust pipe. You didn't hook this one up yet? And then theres that other port next to the exaust flange in your last pic.?
__________________
Dave
'93 Ranger XLT 4.0, 4x4, 179,000 and counting. (For Sale)
'92 F-150 XL I6, M5OD, 4x4, 186,000 and counting. (For Sale)
'90 F-250 XLT 7.3 IDI, E4OD, 181,000 and counting.
'95 Explorer XLT 4L, 4R55E, 4x4. 156,000
Hiding in my own little corner of the world!
  #9 (permalink)
Old 02-14-2008, 07:35 PM
Jake S is starting off with a positive reputation.
You need to have a tube that goes from the pass. side ex. manifold to the port thathas a pipe on it in the last pic. BOTH sides need to flow through the turbine housing to get the turbo to spool.
__________________
1986 F-250 SC 4x4 6.9L IDI, 088 ATS turbo, 4" exhaust, ZF5, NP208, D50/10.25, 3.55's, 9' Fisher Speedcaster, 102k miles
  #10 (permalink)
Old 02-14-2008, 08:02 PM
WOW, I knew that but it never came to mind, damn...i knew this the whole time.
wow, thanks for reminding me.
  #11 (permalink)
Old 02-14-2008, 10:11 PM
turboman24 is starting off with a positive reputation.
Kyle G. can i ask you where you got that turbo kit at. Never seen that set up before.
When you get it working can you tell me how well it works. If it is cheap i might invest in one because $2000 for an ATS one is too much for me especially since i am starting college.
Thanks
Adam
__________________
Psalms 3:5
"I lie down and sleep; I wake again, because the Lord sustains me."
  #12 (permalink)
Old 02-14-2008, 10:28 PM
Well I just got it done and it works pretty good.
I got it from a local diesel mechanic for about 450$ for everything, but i am sorry i researched the company (Turbo Engineering INC) and they don't exist anymore. The kit I have is old, probably from the mid 90's.
  #13 (permalink)
Old 02-15-2008, 11:53 PM
Well got a problem...test drivin the truck after checking for oil and stuff, loose all boost pressure and turbo locks up........wtf.
  #14 (permalink)
Old 02-16-2008, 12:03 AM
George D.'s Avatar
George D. is starting off with a positive reputation.
So now it wont spin free by hand? sounds like the bearing seized. Did you pre lube the turbo? Or is it seizing only when running? if so check the shaft for play and see if the impeller or turbine are hitting the housing. Could the turbo be some thing the mechanic had replaced because it was bad?
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #15 (permalink)
Old 02-16-2008, 12:22 AM
maybe, I dont know, but I am gonna see if i can free it up and moving again.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
