Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-16-2008, 01:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
How did you wind up routing the oil lines?
For pressure it looks like you tee'd off the oil pressure sending unit.
Where is your return going to?
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-17-2008, 01:24 AM
KyleG is starting off with a positive reputation.
My return is going to the hole where the CDR was. I found the problem...it was a clogged check valve on the oil resevoir, It is good now I pre-oiled everything and restarted it, its fine now.
  #18 (permalink)
Old 02-17-2008, 03:15 AM
George D.'s Avatar
George D. is starting off with a positive reputation.
Thats definately a good thing.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
