02-14-2008, 12:24 AM
HP Tuners Fuel Injection Tuning Software!
Hello FTE!
HP Tuners has recently released Fuel Injection Tuning Software for 2005-2007 Mustang and 2004-2007 V8 Gas Trucks! This is HP Tuners' first step into the Ford tuning market and we are working on expanding our product line to support other Ford vehicle types and enhance scanner support over the coming months, exciting times ahead for sure!
We want you to ask yourself-Are you satisfied with your tuning solution? If you want to do more than just select a tune from a list, HP Tuners is the tool you need!
As you are probably aware, today's fuel injected vehicles need to be tuned for most modifications that are made to the vehicle. This means that with most traditional handhelds you need to send the unit back to have it re-programmed, or wait for someone to send you a new file, every time you change something on your truck. With HP Tuners you have a comprehensive scanner and editor package that allows you tune your vehicle when you want! If you make a change to the engine, tune it. Tune it as many times as you want!
Whether you are simply correcting the speedometer on a 2007 F150, or tuning a twin turbo Mustang, HP Tuners VCM Suite is the tool you need. A single interface allows you to tune multiple vehicles, with prices starting at $499.00! If you want to record data without a laptop in the vehicle, or record wide band information as well, go with the Pro for $649.00.
Here are a couple screenshots of the software:
HP Tuners eliminates the need for a unique piece of hardware for each vehicle tuned. If you have a 2005 F150 and a 1007 Mustang, you don’t need two handhelds. Use one MPVI and tune them both!
If you already have an MPVI for your GM tuning needs, all you need to do is download the FREE software upgrade and purchase Ford credits! That’s right, the same piece of hardware allows you to tune Ford and GM Vehicles today! In the future, the same piece of hardware will support Dodge as well! If you do not yet own an HP Tuners interface, buy a Pro or a Standard and start tuning!
Are you pretty much happy with the way your Ford runs, but think it can be improved just a little, if you could raise just the shift point? With HP Tuners you can read your existing tune, and make the changes yourself! You don’t have to start totally from scratch like you may have to with other products!
We don’t limit you to a couple of user options, or pre-canned files. You have full access…if the PCM controls it, you can adjust it!
From a hardware perspective our existing and proven MPVI hardware was designed with Ford protocol support from it's initial launch in 2006 and provides the same robust base for Ford tuning. VCM Suite software integrates Ford tuning into a familiar look and feel for existing users.
For more information please email us!
Thank you!
Jay Payson
HP Tuners
Reason: Typos
