valve lifter change.
Old 12-28-2002, 01:11 AM
grclark351's Avatar
grclark351
grclark351 is offline
Old 12-29-2002, 08:38 PM
webster's Avatar
webster
webster is offline
351M f-150 4x4 Is it possible to remove and replace the valve lifters without pulling the manifold? Maybe using some sort of parts grabber. Pulling them through the head.. Webster
Old 12-29-2002, 09:07 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
I would say no. They are hard enough with the manifold off. They get a varnish built up on them, and they can be very hard to get out. The manifold is heavy, but if you mark all the hoses and wires, it's not too bad to take off. You can leave the carb on if you want.
Old 12-30-2002, 12:46 AM
dustinleavitt2000's Avatar
dustinleavitt2000
dustinleavitt2000 is offline
I recently removed my lifters and I did it without removing the intake manifold. All I did was speand like 5 bucks on a lifter puller at my local auto zone, the lifters on the inside are easy to pull out but the ones on the outside are pretty difficult because only the puller will fit through the little hole so what I did was pulled it from the hole and then let go of it, I then took a telescoping antenna with a magnet on it and fished out the lifter from an angle.
Old 12-30-2002, 07:59 AM
shazam's Avatar
shazam
shazam is offline
>Webster
OK I'd say there are Some Motors that you can change them WITHOUT removing the Intake ........ But the 351M/400 isn't one of them.
the only holes in the head are only big enough for the pushrods to fit through. So how'd you get the lifter out once you got it out of the lifter bore is the tough part.
Old 12-30-2002, 11:19 AM
beartracks's Avatar
beartracks
beartracks is offline
Maybe he pulled em out through the freeze plug holes. Heh, heh!
:P
Old 12-30-2002, 06:16 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
The intake comes off these engines so easily it hardly seems worthwhile to try doing it without removing it.
Old 12-30-2002, 07:07 PM
Brian S's Avatar
Brian S
Brian S is offline
"the only holes in the head are only big enough for the pushrods to fit through."
I made this assumption a couple months ago too when I looked at the 4V heads. 2V has a large opening in the center.
http://images.channeladvisor.com/Sell/SSProfiles/20052540/Images/351Auscollage400.jpg
I still wouldn't do it without removing the intake. It doesn't get much easier than a dry intake.
Old 12-30-2002, 09:44 PM
dustinleavitt2000
I am telling you it can be done i have a 351m and I changed the lifers without taking the intake off. there are only little holes for the push rods on above some of the lifters, in the middle look and the guys pictures there is a big gap. the lifter puller will fit down inside the little pushrod holes, simply pull it out and let it drop down inside, then get a magnet or a pair of tweezers and fish it out from the hole in the middle of the head, it only took me like 15 minutes to pull them out after i got the valve cover off.
Old 12-30-2002, 09:45 PM
dustinleavitt2000
just remember when someone says you can't do it a true redneck will either find some obscure and seemingly impossible way of doing it or he blows himslef up in the process.
Old 12-31-2002, 09:23 AM
beartracks's Avatar
beartracks
Farm out!
Old 12-31-2002, 12:44 PM
webster's Avatar
webster
webster is offline
I believe it! So what lifters did you put back in? What was the result in sound? Webster:+
Old 12-31-2002, 08:11 PM
dustinleavitt2000
it did make mine sound a little better. yes i did replace the lifters
Old 12-31-2002, 08:12 PM
dustinleavitt2000
trust me you can replace them without removing the intake but take my advice i did one side with it on and i got so tired of dropping the lifters i just took the intake off.
just remove the intake its not difficult.
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: valve lifter change.
