Brake Job on a 2000 Ford F150 - Ford Truck Enthusiasts Forums
Old 12-31-2001, 01:58 PM
jetski_vegas jetski_vegas is offline
jetski_vegas is starting off with a positive reputation.
I am replacing my brakes on my 2000 ford f150. I got the calipers off fine but the rotors need to be turned and there is a brace or a bracket that the calipers fit into. This brace/ bracket needs to come off so that I can pull the rotor off. The bolts holding them on are on pretty damn tight and my question is what size socket do i need to get those bolts off I dont have the size in my tool box so before i go to the store to buy one I would like to know what size. Any help would be great. Thanks.
Steve
Old 12-31-2001, 06:12 PM
dship dship is offline
dship is starting off with a positive reputation.
just did a front brake job on my 98 4x4. The size of socket you need is an 18mm. also might have to lube back of rotor with some spray and tap on rotor with wood block. It took me about 2 hours to get my rotors off only to find they were scrap.. Had to buy 2 at $41. I put loctite on the bracket bolts and caliper bolts also to keep them from coming loose
Old 01-02-2002, 10:55 PM
h1vc h1vc is offline
h1vc is starting off with a positive reputation.
2013 F150 What size are the caliper bolts? Turbo Dog 2009 - 2014 F150 4 12-24-2014 09:15 AM
Brakes froze out of town, no tools, looking for bolt sizes. Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 20 12-20-2014 06:07 PM
How-to: 1984 Ford F-350 front brake caliper removal (F350) astembridge 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 06-12-2013 09:44 AM
caliper retaining bracket bolt size????? f-150 on 22's 1997 - 2003 F150 1 07-27-2010 12:38 AM
Caliper Banjo Bolt Size? d0n_3d 1997 - 2003 F150 3 09-07-2007 01:16 AM
Tags
150, 2000, 2003, 7700, brake, break, f150, ford, front, job, pictures, size, socket, tobrake, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
