long arm & air instead of leafs...
Old 02-14-2008, 06:35 PM
Sawsall's Avatar
Sawsall
Sawsall is offline
I have the body off the 79 frame... getting ready to clean it up, paint & re-seal the motor up...
Since I have to move the rearend forward 3 inches to match the 66 body, I was thinking how easy it would be to move the front spring mount further forward and fabricate long arms and bolt it to the spring perch on the rearend... make a panard bar & mounts... and airbag it...
your thoughts welcome...
Old 02-16-2008, 11:01 AM
Texas Jim's Avatar
Texas Jim
Texas Jim is offline
saw,
Whynot just have new main leafs made. At a spring shop, they're easy to make,not very expensive. This way you can get whatever length you need and even get the eye reversed inorder to drop it lower w/ your air bags.
Old 02-16-2008, 02:45 PM
Sawsall's Avatar
Sawsall
Sawsall is offline
Yep, I thought of that... Just something I thought of, and bring the suspenstion out of the horse & carraige age...
This is wierd, I thought I posted this, but came back & didn't see it so I reposted... now there is 2 posts.
Old 02-17-2008, 12:25 AM
garbz2's Avatar
garbz2
garbz2 is offline
I am using a two link and center long bar suspension with Bilstien Coil overs in my Uni.
The shorter you keep the bars the better off the handling will be with torque loading an twist. Bags need all the help they can get in this area. Also use a good set of shocks for dampening. Bilstiens will be the best measured to fit.
Garbz
Tyler S
43
02-25-2014 03:05 PM
TheRedPheonix
06-25-2012 06:13 PM
Yukon350tbi
11-01-2010 12:18 AM
jniolon
32
01-25-2010 07:04 PM
3golfjack
09-10-2009 04:15 PM
Quick Reply: long arm & air instead of leafs...
