Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
is the truck to big
Old 02-13-2008, 07:44 PM
white302's Avatar
white302
white302 is offline
is the truck to big
i have built a 1979 ford f150 4x4 truck. it has a 10in suspenion lift and a 5 in body lift. it came with a 351modified400 and a divorce transfer case. I bought all rough country suspenion shocks and springs and other stuff. I put a set of 42 in supper swampers on it. it is big now but what is ya'lls opion on a set of 54in tires.
Terry
Old 02-13-2008, 09:30 PM
ubereal2's Avatar
ubereal2
ubereal2 is offline
NO!!!!!!!!!!!!
It Can't be too big.
Any Pictures.
Bob
Old 02-14-2008, 06:12 AM
3broncocrazy's Avatar
3broncocrazy
3broncocrazy is offline
Let's see it!! put the 54s on
Old 02-14-2008, 04:58 PM
confederate_mudder's Avatar
confederate_mudder
confederate_mudder is offline
I cant see it going very far with 54s
Old 02-14-2008, 08:21 PM
white302's Avatar
white302
white302 is offline
Hey I thanks for the replies I will post pics when I figure out how.
Old 03-04-2008, 08:34 PM
BEERHUNTER97's Avatar
BEERHUNTER97
BEERHUNTER97 is offline
What kind of gears are you running? I'd look into some deep gears if you're going that high on tires. Your Trans will thank you man.
Ry
Old 03-05-2008, 03:53 PM
white302's Avatar
white302
white302 is offline
I have contacted rough country and told them all I was doing to the truck and they sent me a set of 6:55 gears I thinkall I know is they where a little over 400 dollars. Still working on truck it has 48 in supper swammper iroks still working on 13 inch lift and 5 inch body. to get the 54 inch tires on it
Old 03-05-2008, 08:01 PM
BEERHUNTER97
Sounds sweet man, I can't wait to see pics!!
Old 04-06-2008, 07:31 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
i dearly hope that you or someone has swapped out those 1/2 ton axles in lieu of either cromo'd/built D60/10.25 or a set of rockies! just hitting the brakes too hard with 54's will break that D44/Ford 9!
also, not sure i have ever heard of 6.55 gears?!?!
you're truck is going to fall off the frame with a 5" body lift! that is just stupid! bring that down to a 2" body lift and add some suspension lift if needed (which i doubt). otherwise, stay outta my part of town!
i'm thinking BS until i see some pics, nothing personal, just seems theres a lot of people running 15" of lift and 54" michies!
-cutts-
Old 04-06-2008, 08:07 PM
dragogt's Avatar
dragogt
dragogt is offline
Take a READ, and see why thats a BAD IDEA... https://www.ford-trucks.com/forums/7...he-how-to.html
Old 04-06-2008, 09:00 PM
cletus_the_red's Avatar
cletus_the_red
cletus_the_red is offline
I would say that the max for a body lift is 3 inches, but thats the biggest they are sold right?
Old 04-06-2008, 11:08 PM
fishmanndotcom
for a reason.... even 3" body lift is scarey in my opinion. no one thinks to use larger sized bolts even though they are longer. it'd be a different story if he was using 3/4" grade 8's or something. however i just dont see it.
-cutts-
Old 04-06-2008, 11:26 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
No pics in a month and a half since to OP.. I call BS. He's probably madly fabbing away with hockey pucks for the body lift, and light bars from a Ted Nugent concet for a subframe, just to make it look like he described.
In the mean time.... I have an 07 PSD, where can I get some 54's so that my quad front shocks dont look out of place. And how can I cut down my brake calipers so I can fit 15 inch wheels on.
Old 04-07-2008, 02:50 AM
bla1879's Avatar
bla1879
bla1879 is offline
i found it
dude you guys i found his truck check it out!
but i dont think he put the 54s on it yet
hahaha the things people do with their money...
Old 04-07-2008, 02:10 PM
chrono4's Avatar
chrono4
chrono4 is offline
in..... thanks for the chance.
Quick Reply: is the truck to big
