I have a 1996 f-250 all stock except down pipe and the 6673 filter. I think i might have a boost problem when i am driving on the highway unloaded my boost is 2psi and sometimes just under is that a normal boost on these trucks or low? Even unloaded on a hill it will smoke a little black and towing it smokes black just a little even on flat. I unplugged the sensor and i dont see any change in the psi its still reads 2 psi down the highway.
If your truck is all stock you won't build any significant boost until over 2200 rpm's and the max should be about 16-17 psi and you will need to run some pretty high rpm's to see that.
You need to start looking for exhaust leaks, problem with your turbo, or maybe a intake plenum boot is tore. Also possible that the o ring between the turbo and intake Y is broken.
What's the best way to look for leaks on both sides?
The exhaust side look for formations of soot around the exhaust manifolds, uppipes, and collector gasket. The pressure side pull the intake Y and inspect the o-ring and boots going to to plenums.
Originally Posted by 91 Dually
You unplugged the sensor and it still reads 2 pounds? Sounds like you need to check your gauge and how is it hooked up?
He said he has see 10 psi with a heavy load so didn't really feel that it was the gauge but anything is possible.
