How do I disable anti theft - Ford Truck Enthusiasts Forums
Old 02-13-2008, 06:52 PM
broncomutt broncomutt is offline
broncomutt is starting off with a positive reputation.
I have a 1998 ford explorer I am turning into a rockcrawler. I want to make it so it is a push button start and I need to disable the anti theft so I dont need a chipped key. I have read that if I ground the green and purple wire for the anti theft that that will disable it. Is this accurate and will I then be able to remove the steering column and say goodby to the key. This is going to have full hydraulic steering so I will be removing the whole steering column.
If not How do I shut off the pats system I have called the dealers in my area and they say they cant do it. and I have unplugged the anti theft box and then the motor wont start either.
Thanks for any advice
Old 02-13-2008, 08:43 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I would have a tuner remove it. I can't find a remote start wire guide, but usually fords require a transponder that you wrap around the column. Check out directed's website, they should have several bypass kits available.
Securilock-DELETE? freeranger 2015+ F150 14 06-09-2015 10:31 PM
Anti-theft light jan g 1999 to 2016 Super Duty 4 11-14-2014 08:29 AM
Ford Anti Theft System? bldude2288 Ranger & B-Series 2 10-04-2014 08:57 PM
1999 F-150 Remote Keyless Entry Question pharbach 1997 - 2003 F150 12 11-23-2004 05:08 PM
Anti-theft lock couleeman General Automotive Discussion 2 10-18-2004 02:19 PM
Tags
1994, 1997, 2004, 2006, anti, bypass, disable, disabling, disengage, explorer, ford, forum, pats, system, theft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
