Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-13-2008, 04:22 PM
javi2001's Avatar
javi2001 is starting off with a positive reputation.
Low economy at citi???
Hi guys my F150, 1995, 4.9L + E4OD is runing very nice on highway but driving by town it actually "Drink" fuel.
This truck is totally stock, good service, all the tuning and maintenance stuff is recent, even brand new Ford injectors. The only thing modified is a restrictor plate installed at EGR valve.
I was wondering, the EGR helps to reduce fuel used?? isn't it? Way people install that restrictor plate at EGR???
Thanks in advance, any input will be appreciated.
Upss I forgot, right now there is no knocking sensor installed, I'm using 95 octane gasoline I can't feel any knock noise.
__________________
Javi2001@cantv.net
Venezuela
4.9L carby +E4OD +1356 Electric shift T-Case + WARN Auto hub's +Baumman TCS controller, F150, 4WD, 1986!!! will be MFI shortly
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-13-2008, 04:23 PM
Silver Streak is gaining momentum as a positive member of FTE.
The missing knock sensor could be your problem. Without it the PCM retards timing to protect the engine and that can kill mileage.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #3 (permalink)
Old 02-14-2008, 11:17 AM
lordoflivernois is starting off with a positive reputation.
This is pretty much the same problem that im haveing.. Does it foul out plugs?
  #4 (permalink)
Old 02-14-2008, 08:36 PM
javi2001's Avatar
Ok tahnks I'll install sensor this weekend, then will see. Any extra comments?
__________________
Javi2001@cantv.net
Venezuela
  #5 (permalink)
Old 02-15-2008, 12:04 AM
hoxiii's Avatar
hoxiii is gaining momentum as a positive member of FTE.
what kind of bad economy are you actually getting? black smoke out tailpipe? heavy fuel smell?
Justin
__________________
86 150 SuperCab Shortbed 4x4 conversion XLT Lariat, 300, 435
85 150 4x4 convert, 390 FE, NP435, 205, 9" TTB 44
R.I.P 8-26-07
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=161169&.jpg
  #6 (permalink)
Old 02-15-2008, 09:40 AM
javi2001's Avatar
Quote:
Justin
Ok let me explain, there is no black smoke, no fuel smell, no nothing, just the truck is using a lot of fuel on city. It is giving me around 9 - 10 MPG, on highway gives around 15 - 17.
There are no fuel leaks, apparently...
__________________
Javi2001@cantv.net
Venezuela
  #7 (permalink)
Old 02-15-2008, 01:50 PM
hoxiii's Avatar
Is that 10 per US gallon or imperial (i see you're in venezuela, i don't know what you go by). If it's 10 per US that really isn't that bad for that truck. If you're getting 10 imperial i would agree that there is something majorly wrong.
When was the last time it had a tune up? have you tried some basics like checking the timing,fuel filter, and aircleaner?
Justin
__________________
R.I.P 8-26-07
  #8 (permalink)
Old 02-15-2008, 07:32 PM
javi2001's Avatar
Thanks Justin, here in Venezuela we use liter, I did make simple conversion to US gallon, so you can help me.
Basic tune up including Sparks plugs, all filters, oil, cables, timing was performed just 2 months ago.
That same engine was running previously on my old F150, 1986 using a carburetor and was giving me 11.5 - 12 on town and 15 - 16 at highway I guess same engine running with EFI setup MUST run with less fuel, isn't it???
__________________
Javi2001@cantv.net
Venezuela
  #9 (permalink)
Old 02-15-2008, 07:39 PM
fmc400's Avatar
fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.
I'd guess it's the EGR valve block-off plate causing problems. It's the only thing on your engine that isn't in perfect order. Engines with EGR are calibrated to run leaner with more advance than engines without EGR - without your EGR valve you are changing the ratio of inert exhaust gas to combustible air\fuel, and it is throwing off the computer and disrupting your timing curve. You need to hook the EGR valve back up; that's what's wrong. There is no reason to block off the EGR valve anyway - it's actually to your benefit. Inert exhaust gasses reintroduced into the combustion chamber help to lower combustion temperature. There are absolutely zero performance gains from losing the EGR setup no matter what people say. It is a common misconception that it hurts performance because people think it is just "smog junk." That assumption could not be any farther from the truth.
  #10 (permalink)
Old 02-17-2008, 02:34 PM
javi2001's Avatar
Ok I'll remove the restrition plate, is not dificult and could take just 5 minutes, then will see
Now I'm taking new readings since presvious number was not using A/C, now it is working and I'm specting even worse readings...
__________________
Javi2001@cantv.net
Venezuela
  #11 (permalink)
Old 02-17-2008, 04:29 PM
Quote:
Your problem may lie in that statement. The carb engines use a different combustion chamber that requires more timing to run efficiently. If you're using that engine with a stock EFI system it probably doesn't have anywhere near the timing it should have. You could try bumping the base timing up 8-10 degrees from stock and see if that helps, but that's a bandaid fix for a much larger issue.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #12 (permalink)
Old 02-17-2008, 05:16 PM
javi2001's Avatar
Ok let me explain a bit...
MY truck originally was F150 1986, 5 years ago I got in yard a "used almost new" 300 engine coming from a EFI Econolione 1991. I just took that engine, removed all EFI stuff and installed the stuck carby.
Last year, my truck was roll over and I lost the passenger cab, the fast and cheap solution in my country was buy in yard "half" F150 1995. I did remove everything over main frame then installed all the "new" parts coming from the 1995 truck, including all EFI stuff, so the engine is running EFI again.
My truck is basically a 1995 F150 on a 1986 frame, 1991 L6 engine and 1995 E4OD tranny updated to 2000, a little Frankenstein someone said...
__________________
Javi2001@cantv.net
Venezuela
  #13 (permalink)
Old 02-20-2008, 12:52 PM
javi2001's Avatar
Update...
Hey guys, I did remove the restrictive plate from EGR, but until now I can't tell the difference, no more no less power but fuel used seems to me is same.
I did not install the knock sensor yet, engine block need some threat job
__________________
Javi2001@cantv.net
Venezuela
  #14 (permalink)
Old 03-11-2008, 01:34 PM
javi2001's Avatar
Updated info
Hi all, after several weeks trying to find my Low Economy problem, I notice this:
1° Problem is getting worse and now truck is using too much fuel even driving on highway.
2° Sometimes there is a bad odor from exhaust pipe, no black smoke.
3° Knock sensor is not installed yet since the engine block needs a new thread to install it
I dont have to much experience on this kind of problems, so I guess any info about the troubleshooting procedure will help.
__________________
Javi2001@cantv.net
Venezuela
  #15 (permalink)
Old 03-11-2008, 03:26 PM
The first two symptoms sound like you might have a plugged up exhaust.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
