Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 03-11-2008, 06:49 PM
Col Flashman's Avatar
Col Flashman is gaining momentum as a positive member of FTE.Col Flashman is gaining momentum as a positive member of FTE.
I can only re-enforce what S/S has just stated about the Exhauste being plugged.
And just For Your Information, the proper terminology is I-6, as in Inline 6.
The L-6 is the Flathead 6 designation because of the way the Valves are setup in the head in an L configuration.
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 03-13-2008, 01:59 PM
javi2001's Avatar
javi2001 is starting off with a positive reputation.
hummm interesting point, I'll check that. Any more ideas guys?
__________________
Javi2001@cantv.net
Venezuela
4.9L carby +E4OD +1356 Electric shift T-Case + WARN Auto hub's +Baumman TCS controller, F150, 4WD, 1986!!! will be MFI shortly
  #18 (permalink)
Old 03-13-2008, 11:11 PM
optikal illushun's Avatar
optikal illushun is starting off with a positive reputation.
how long ago was the oxygen sensor replaced?
__________________
93 F150 XLT 4x4
Modded 300/Built E4OD
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
1988 F350 Custom 4x4
7.3 IDI/ZF
RayWel lid w/ Opti'ized ram air
"G" codes
True 2 1/4" duals w/ packs
315/75/16 ProComp Xtreme ATs
16x8 White waggies
Alpine/Infinity stereo
3G soon
  #19 (permalink)
Old 03-15-2008, 12:33 PM
javi2001's Avatar
Good point. 2 or 3 years ago.
Injectors were cleaned 3 months ago. Engine doesn't hesitate, no rough idle, no black smoke, no any failures, it runs fine but is using too much fuel and condition is getting worse every week.
__________________
Javi2001@cantv.net
Venezuela
  #20 (permalink)
Old 03-16-2008, 03:23 AM
chrono4's Avatar
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
Have you checked your fuel pressure? if the bypass regulator is stuck/bad, it can ramp up fuel pressure and blow through the injectors, resulting in a rich condition and very poor mileage.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #21 (permalink)
Old 03-16-2008, 03:26 AM
chrono4's Avatar
And to add to what I originally posted: A bad regulator would also explain the highway mileage being so much better than in town. You use more fuel on the highway, so it was being burned more efficiently, but as the problem got worse, it can't burn all the fuel, even under load on the highway.
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #22 (permalink)
Old 03-16-2008, 12:35 PM
javi2001's Avatar
Heu Chrono4, that's a very good idea. I don't have tester for fuel pressure, but I'll check next week.
Thanks a lot...
__________________
Javi2001@cantv.net
Venezuela
  #23 (permalink)
Old 03-16-2008, 12:45 PM
chrono4's Avatar
No problemo. We're all here to learn and be learnt.
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #24 (permalink)
Old 05-23-2008, 11:09 PM
javi2001's Avatar
Ok guys finally I got pressure readings...
It has 49 - 50lbs engine runing idle
it has 59 - 60lbs engine runing idle AND vacum line disconnected from pressure regulator
And 60lbs Engine off fuel pump on
It looks a bit high, isn't it? what's the normal press. for 4.9's
__________________
Javi2001@cantv.net
Venezuela
  #25 (permalink)
Old 05-24-2008, 04:58 AM
srercrcr is starting off with a positive reputation.
.....but you'd see black exhaust (unburned fuel).
__________________
Steve Robbins
'83 XLT Super Cab Long Bed 300-6 (20 mpg hwy) 4OD 3.08, one-owner ordered from the Factory in May '83 with a page-full of options, 175000 miles, all stainless exhaust. Take a look.....
http://s45.photobucket.com/albums/f88/srercrcr/Ford%20F150/?action=view&current=FordF15083.jpg
  #26 (permalink)
Old 05-25-2008, 07:49 PM
javi2001's Avatar
Ok, there is no black smoke.... yet......
but it smell like unburned fuel.
I left installed the pressure gage for all weekend and I notice also, after stoping engine, pressure is reduce slowly to 0 psi in about 3 hours, I wonder...
How often the injectors can leak fuel? maybe they have to much wear and are leaking fuel to intake manifold???? causing the rich condition and the high idle also...
__________________
Javi2001@cantv.net
Venezuela
  #27 (permalink)
Old 06-24-2008, 06:25 PM
javi2001's Avatar
__________________
Javi2001@cantv.net
Venezuela
  #28 (permalink)
Old 06-25-2008, 12:07 PM
Motorhead351's Avatar
Motorhead351 is starting off with a positive reputation.
Maybe make a list of what you have done.
Plugged catalytic converter/exhaust was mentioned but it wasnt clear if you even had one or if it had been checked.
Are you able to pull codes?
  #29 (permalink)
Old 06-25-2008, 01:24 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Yes, have you pulled the codes? See Ford Fuel Injection for a DIY method.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #30 (permalink)
Old 06-25-2008, 01:29 PM
SR_Crewchief is starting off with a positive reputation.
Are you still running 95 octane? If so Why? If available, try 87-89 octane...once you've replace the knock sensor that is.
Have you pulled codes recently? If your getting sensor related codes verify that the sensors in question are functioning correctly. Since your fuel pressure appears to be good, then the problem usually relates to bad data been delivered from one or more sensors.
__________________
1988 F150 std cab LB 4x2 300/4.9l M5OD 3.08's 288,000+ original miles.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
