1979 Ford F350 4x4 question
Mil1ion, I've been wanting to ask you.. is that shipping weight their actual weight you think? curb weight? I would think so but it always seems on the low side.. i see people talking about 5500lb stock F250s, no way in hell they can be that big if my truck is 3800lbs and the F350 4x4 is 4500lbs.
if it's true (and i have faith in your mil1ion :P ) then it really makes these trucks that much better. 79' F350 4x4 weighs less than a modern F150 2WD
Each truck will weigh more or less, depending on the options you choose. Obvioulsy, the more options, the more the truck will weigh.
This will give you an idea of what to add to the base weight of a truck.
1974 camper loading weight info. You will have to look for the F250 4x4 to get close to what you actually have, but still, this will give you an idea of how much extra your truck weighs from bone stock.
http://s14.photobucket.com/albums/a315/Masterbeavis/73-79%20Ford%20Trucks/1974%20Truck-Camper%20loading/
Originally Posted by F350moneypit
I am not exactly sure about a '79 F-350, but my '75 F-250 with '78 one ton axles, all cast iron big-block, 8 quart oil pan, 36 inch tires, and 20 gallons of gas weighs 5240 lbs. Its nice having a truck scale just a mile down the road!
Originally Posted by tude
im not sure what mine weighs in at but id bet im 400+ over you, i have a flatbed, divorced t-case, side boxes.....but basicly the same truck as you described. 79 f350, (dana 70s) 460, C6, and on 36's....but i rarely have gas lol
