i ve always been imports but i recently purchased an old 69 ford f 100 with a 390 ,stock bore with 352 heads that has
stainless valves size i dont know as well as port and polish dont know ,it has a mild erson cam duration only dont know that either ,and its currently set up with a edelbrock performer 390
intake manifold with a carter 650 cfm 4v carb it has dual
exhaust with stock exhaust manifolds and and 3 inch dumps oh yeah im guessing the compression is about 10.6 to 1
this motor is strong.......but i want more ........so heres the question if YALL can
im looking for a different
intake setup i want to keep my carb but i want a tunnel ram dual quad 360 degree intake manifold that will work with my stock distrib. i am having no luck finding any for the fe engines or tunnel rams period i know the cons but i love the gasser look i think offenhauser makes some but i cant find them
on the other hand......
i would like to consider a blower setup 671 871 setup but i dont know if my compression and mild upgrades is enough to select the type of blower i would like to use
theres plenty more i dont understand but at this time these are my two options im wanting to consider ....thankx
basically im lost and dont know what suppliers are out there and really what options im up against or other
