2004 f150 5.4L mass air flow sensor - Ford Truck Enthusiasts Forums
Old 02-13-2008, 11:04 AM
topwhop topwhop is offline
topwhop is starting off with a positive reputation.
Has any one ever changed or cleaned the mass air flow sensor . is it possible o clean it?
Old 02-13-2008, 11:25 AM
JimTex JimTex is offline
JimTex is starting off with a positive reputation.
Sure, cleaned mine twice in the 64,000 miles. It's easy.
Old 02-13-2008, 11:30 AM
It is on the side of the intake going into the throttle body.
1. Pull up or squeeze the red retainer clip and unplg the wire.
2. Remove two torx screws and pull out the unit.
3. Spray the little wires with MAF or Electronic cleaner, available at auto parts stores.
4. let air dry for a couple of minutes. DO NOT TOUCH THE LITTLE WIRES!
5. Reverse to install.
Takes about 5 minutes. I think the spray cleaner was about $10 and will last forever.
Old 02-13-2008, 11:34 AM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
As Jim states, it's very easy. I just did mine this past month at 85K.
Old 02-13-2008, 12:26 PM
Brian429 Brian429 is offline
Brian429 is starting off with a positive reputation.
Could a dirty MAF be causing decreased MPG?
Old 02-13-2008, 02:23 PM
Quote:
yes, it could, but so could a dirty fuel filter, dirty air filter, or it could be the 10% ethanol, or it could be plugs beginning to wear.
I know when the ethanol hit here, I lost about 1 mpg immeddiately.
Old 02-13-2008, 04:37 PM
belandd belandd is offline
belandd is starting off with a positive reputation.
Maf
Book says to clean it with denatured alcohol ONLY!
Old 02-13-2008, 07:45 PM
bansheeduner bansheeduner is offline
bansheeduner is starting off with a positive reputation.
is it worth it to buy a better mass airflow sensor jw
1988 f250 truck maf or mat mass air flow sensor jtfordman 1987 - 1996 F150 & Larger F-Series Trucks 2 07-17-2012 10:26 PM
2003 4.2 rough idle in gear Stan's 04 1997 - 2003 F150 2 02-07-2011 10:02 PM
What size allen wrench for Mass Air Flow Sensor??? SWA2004 2004 - 2008 F150 6 03-26-2010 09:41 PM
mass air flow sensor location baseba8311 3.8 & 4.2L V6 1 06-26-2007 10:06 AM
Where's the mass air flow sensor on a 86 2.9? unioncreek 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 2 01-19-2007 11:52 PM
Tags
2004, 2005, 54, 54l, air, check, f150, flow, ford, liter, maf, mass, remove, sensor, supercrew
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
