piston ring gap location
Old 02-13-2008, 09:05 AM
EFM's Avatar
EFM
EFM is offline
can someone tell a novice engine builder if putting piston ring gap over piston pin bosses is the correct location?
351C build in progress
Old 02-13-2008, 04:32 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
As long as the gaps of each ring do not line up with one another, it shouldn't really matter. Those things will rotate when your engine is running anyway, so starting position isn't a big deal. On engines with three rings, I clock each gap 120° from each other.
Emmett Coffman
06-20-2015 08:13 PM
breezesboy
05-07-2015 06:29 AM
Bucsfan552
08-02-2009 10:21 AM
Argess
02-07-2009 08:58 PM
mercman78
02-16-2007 11:29 PM
Quick Reply: piston ring gap location
