Your 1992 systems Horn does not ground through the Speed Control Servo/Amplifier Assembly.
Your clockspring is more than likely bad and yes the clockspring is a common problem.
Hi
I´m wondering about this info in my search for a new clockspring ...........
can you help me out here ??
seems like there is no clockspring in my ´92 E150 with cruisecontrol .....
That just means that that place doesn't carry your part number. Shop around and see if you can find one from another source. It still has a clockspring. Good luck.
