Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 02-12-2008, 10:48 PM
Cow Hauler Cow Hauler is offline
Garage is empty, add now
Cow Hauler is starting off with a positive reputation.
Question Motor knocks when cold
I have a 05 F350 4X4 DRW that makes a knocking or heavy valve tick noise would be the best way to describe it, when the motor is cold and first started. When I say cold I mean 20 degree's or colder.
Once the motor runs for a little bit the noise fades away.
If the truck is pligged in it very rarely makes this noise.
Has any body had this problem?
The truck doesn't have any upgrades.
I took it to one dealer and they said that they could not hear anything, But you would have to be deaf not to hear it.
I think am going to get a 2nd opinion from another dealer.
Any input would be apprecieated.
  #2 (permalink)
Old 02-13-2008, 07:52 AM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.
The oil is still too cold to flow to all the parts that need it. When cold, it is like a gel and just doesn't get spread around that easily. As it warms up, it starts flowing and quieting all the parts. If you can plug it in, then do so. Cold starts are one of the engines worst enemies.
__________________
99 F350SD Lariat Crew Cab 7.3L PSD - 4x4 - DP Tuner - Custom HD trans
86 Bronco 302 EFI (Second one!)
Quit whining! You voted for him!
http://i86.photobucket.com/albums/k102/billybob69_photo/90x90_email_signature_HIGHMILER-1.png
  #3 (permalink)
Old 02-13-2008, 09:31 AM
Thanks BillyBob 69.
I am running Rotella 15w40 do you think it would be better to go to 10w30 in the winter time?
Thanks.
  #4 (permalink)
Old 02-13-2008, 10:05 AM
BillyBob69's Avatar
I run the Rotella 15-40 all year with no problems. You could switch to a thinner oil for the winter but remember that when it heats up, it then has less protection for your internal parts. Depending on how hard you use your truck, it may not matter.
__________________
  #5 (permalink)
Old 02-13-2008, 06:04 PM
Thanks for your input.
Keep it between the lines!
  #6 (permalink)
Old 02-13-2008, 10:14 PM
BillyBob69's Avatar
Oh I know it may seem trivial, but also make sure you aren't low on oil.
__________________
  #7 (permalink)
Old 02-14-2008, 12:27 AM
Thanks.
I am right at the full mark.
This weekend I am going to take it to another dealer and see what they say.
I have 4 6.0 at work and my Dad has one as well and none of them sound like mine when they are started cold.
If this dealer can't find anything I guess I will just have to live with it.
  #8 (permalink)
Old 02-14-2008, 08:48 AM
BillyBob69's Avatar
Get a real long extension cord an plug it in. Makes a difference on cold mornings. I have a 100ft cord going to mine from the house.
__________________
  #9 (permalink)
Old 02-14-2008, 02:33 PM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
Cow Hauler, you might try 5-40 synthetic next oil change. Mine seems to turn over easier and no romps.
__________________
__________________________
Dean
2002 F350 XLT/7.3L/SC/SRW/LB
3.5"DP-4"Exh/AIS/Isspro Performax/GPR LED/Zoodad/Tru-Cool
IH up-pipes/ATS housing/TM wastegate/PHP tunes
1988 F250 REG CAB 460
  #10 (permalink)
Old 02-14-2008, 02:40 PM
Thanks for the tip DND58.
I have been nervouse about trying synthectics because I have heard that once you start using them you can't go back to regular oil without risking damage to your motor. I don't know if that is true or not but that is what I have heard.
What are the pro's and con's that you have noticed?
  #11 (permalink)
Old 02-14-2008, 03:03 PM
DND58's Avatar
I've heard the same rumors. Many guys in the 7.3 L section disagree. I switched in fall 07 thinking it would reduce injector clatter. I didn't notice much quieter, but my ears are not all that good anymore. Pro's are it spins over faster and fires easier in the cold. Con's are about 2X $$ per oil change. You might try a search through the diesel section on synthetic.
__________________
Dean
  #12 (permalink)
Old 02-14-2008, 06:08 PM
Thanks for the feed back.
It will be interesting to see what the other dealer says about it. My Dad used to work with some of the guys at this other dealer so I am hoping with that connection they will try a little harder to see what is wrong.
If they say nothing is wrong I am seriously going to consider going with some thinner oil.
It makes me cringe everytme I have to start it when it is not plugged in.
I am hoping they tell me it needs a new motor since it is still under warrenty. That would be sweet!! Ha Ha!!
Have a good one!
  #13 (permalink)
Old 02-14-2008, 11:29 PM
Colo79Ford Colo79Ford is offline
Colo79Ford is starting off with a positive reputation.
I dont run a diesel but i have switched back and forth from synthetic to synthetic blends to conventional oils with no problems with the engine or excessive wear at all.
__________________
My truck
  #14 (permalink)
Old 02-15-2008, 07:11 PM
I talked to Ford today and they told me to run either a 10w30 or a synthetic 5w40.
They said that some of the cold start noises have been from the oil being to thick just like you all have said.
Tomorrow I will change the oil and see if that helps. Ford said if it still makes noise after the oil change then to bring it in and they would take a look at it.
Thanks for the pointers everybody!
  #15 (permalink)
Old 02-16-2008, 11:54 PM
Well, I put in the synthetic oil today and it is still making the noise. It helped a little bit but not very much. So the truck is going to ford on Monday.
If anybody is curious I will let you know what Ford finds.
Tags
cold, ford, knocks, motor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
