Fuel Pressure Reg. - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Fuel Pressure Reg.
Old 02-12-2008, 08:30 PM
whopp whopp is offline
whopp is starting off with a positive reputation.
Fuel Pressure Reg.
I have been reading about the fuel system shim idea you guys have been using. 6L out of the box run about 43 psi and spec is 45. What I have been doing to correct this is replace the regulator pintel oring with a new one but installing it backwards so the tapered side is facing the filter housing. I cant see why this wouldnt work on the 7.3L. After doing this mod fuel pressure is usually in the area of 60psi. Just thought I would throw that out there!!!
P0191 Frmtrk Modular V8 (4.6L, 5.4L) 4 02-24-2015 08:39 AM
Fuel pressure question XSleeper Fuel Injection, Carburetion & Fuel System 1 04-29-2014 02:42 PM
In tank fuel pump spec?? dustmote 1968-2013 Full Size Vans 4 11-20-2011 07:50 AM
Fuel Pressure Test Results - Seeking Interpretations & Recommendations PaulDH 1987 - 1996 F150 & Larger F-Series Trucks 16 05-22-2010 05:15 PM
Help with 1990 F-350 Fuel Pressure Problem MudBugn 1987 - 1996 F150 & Larger F-Series Trucks 0 03-22-2006 12:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
