Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-12-2008, 06:51 PM
mongoose289 is starting off with a positive reputation.
coil spring retaining plates
does anyone know if they will interchange with ones from a 78 or 79 bronco/f150?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-12-2008, 08:42 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Are you referring to the coil cups that hold the springs at the axles?
The later model Bronco and 78-79's have a wider bolt spacing on the radius arms so they are not a direct fit.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 03-02-2008, 08:27 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
There are two types.
C6TZ-5A307-A used 1966/70. These are the same as 1966/70 F100 4WD's
D1TZ-5A307-A used 1971/77. These are the same as 1971/75 F100 4WD's.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
