Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-12-2008, 05:57 PM
effie_man's Avatar
effie_man effie_man is offline
Fatty driving the Flatty!
effie_man is gaining momentum as a positive member of FTE.
12V generator ?'s
I recently changed over to 12v on my '53 239 and i got a free 12 v generator that has sat for a number of years. It worked the last time it was on a motor. Its all hooked up and i took a base reading from my battery of 11.60V, with the motor running it slowly drops from that by .01V steadily about every 30s or so. When i throttle the motor up the reading jumps back to 11.60/11.61V until i let off and it drops back to where it was before i throttled and keeps dropping slowly. Im not very familiar with generators over alternators, so i am unsure if this is normal. Any suggestions? I would like to keep the nostalgia look of the generator over the modern look of an alt.
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #2 (permalink)
Old 02-12-2008, 07:54 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Generators will usually need more RPMs to out put the correct voltage, but I should let you know that 11.6 volts will kill a 12v battery rather quickly. You want 13.6-14.4 volts while runing to keep the battery healthy
  #3 (permalink)
Old 02-12-2008, 07:55 PM
effie_man's Avatar
i figured as much just wanted some other opinions on the matter
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #4 (permalink)
Old 02-12-2008, 08:04 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is starting off with a positive reputation.
You may need to polarize the voltage regulator. Now if I could remember how to do that. I wonder how the brushes and commutator are?
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
07 Edge SEL+ fwd
73 Mustang cpe
71 Mustang cpe
  #5 (permalink)
Old 02-12-2008, 09:16 PM
effie_man's Avatar
i think im gonna take it down to a company i know who can test it and find out for sure
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #6 (permalink)
Old 02-13-2008, 01:01 AM
mtflat mtflat is offline
mtflat is gaining momentum as a positive member of FTE. mtflat is gaining momentum as a positive member of FTE.
With the ignition OFF, you polarize the system by taking the field wire off the voltage regulator and touching it briefly to the batt terminal of the regulator.
Generators need to be turning 12-1500 rpms before they put out normal levels of juice. Below that it's a loss.
  #7 (permalink)
Old 02-25-2008, 09:48 PM
effie_man's Avatar
k this is what i did for my generator. The one i spoke about was a chevy one i was trying to mod just so it worked. The generator turned out to be no good so i bought a set of 12v field coils and installed them on my 6v gen and it works great.
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
