Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-12-2008, 02:04 PM
DCSpecial's Avatar
FTE Sponsor
DCSpecial has a very good reputation on FTE.DCSpecial has a very good reputation on FTE.DCSpecial has a very good reputation on FTE.
6.0 Fuel Filter(s) Change
I took some pics in the fall and finally got around to doing somewhat of a step by step to show how to change the fuel filters on the 6.0.
May be of use to those who haven't changed their own yet.
Changing the fuel filters on the 6.0 is fairly easy.
Be for you start, here's the tools you'll need a 36mm socket and 1/2" ratchet, a 24mm socket (1/2 ratchet with an extension), a small flathead screwdriver, and a 6mm hex:
Also, you'll need a drain pan, safety glasses and latex or nitrile gloves if you so choose.
I always use motorcraft filters:
I start with the filter on the frame.
First, use the 6mm hex and loosen the drain plug:
Try and stay as far away as possible to minimize the amount of fuel you get on you during the change, and be sure to have the drain pan in place to catch the fuel:
Now that the housing is completely drained, you'll need the 36mm socket to loosen the filter cap:
Try and stay as far under the middle of the truck as possible and away from the frame rail. Finish loosening the cap and remove the cap and filter:
Pull the filter out of the cap:
Remove the old o-ring from the cap:
Coat the new o-ring with diesel fuel, reinstall on the cap, and install the filter and cap back into the housing.
Reinstall the drain plug
Be sure not to over tighten either one.
With the one under the truck finished, move to the one under the hood.
It is located right next to the oil filter:
Using a 24mm socket, loosen and remove the cap and filter:
Again, you'll have to remove the old o-ring from the cap:
Again, be sure not to over tighten.
Pick up the your tools, drain pan, etc.. and cycle the key a few times to allow the pump to run and then fire up the truck.
__________________
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-12-2008, 02:17 PM
jmaskew's Avatar
jmaskew is starting off with a positive reputation.
Nice instructions!! Thank you for the time and effort into making that manual.
__________________
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #3 (permalink)
Old 02-12-2008, 02:47 PM
69cj is starting off with a positive reputation.
I have read that diesel fuel can make the O ring swell and then the cap will leak. I have read and always use clean motor oil on the O ring and then torque the caps to specs. Have never had a fuel leak or hard start motor doing it this way.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #4 (permalink)
Old 02-12-2008, 02:55 PM
DCSpecial's Avatar
FTE Sponsor
I've never had an issue....but I just put a light coat on it, I don't soak it or anything.
__________________
  #5 (permalink)
Old 02-12-2008, 03:04 PM
Momorris is starting off with a positive reputation.
I'm guessing this truck is 2wd. It looked so nice having all that room to move and not have a driveshaft in your way.
__________________
2005 F250 KR CC 6.0L
DashDAQ - soon to be Phalanx Monitor
ARP headstuds
Silverline Turboback
SCT X3...Spartan and Innovative tunes
DFuser Coolant Filter
  #6 (permalink)
Old 02-12-2008, 03:11 PM
DCSpecial's Avatar
FTE Sponsor
Yep, looks like it was on the 06 F-450 2wd.
Definitely more room vs. when I do them on my 07.
__________________
  #7 (permalink)
Old 02-12-2008, 03:27 PM
Frankenbiker's Avatar
Frankenbiker is gaining momentum as a positive member of FTE.
No driveshaft, no crossmember, no skidplate... It took me longer to change the HFCM filter than it did to change the secondary filter, oil filter, and oil, COMBINED. Whoever put it there (in the design) should be forced to change 1000 or so of them.
-blaine
  #8 (permalink)
Old 02-12-2008, 03:50 PM
Quote:
-blaine
You are right about that. It is a PITA. The easiest thing I found to use is a flex headed ratchet.
__________________
ARP headstuds
  #9 (permalink)
Old 02-12-2008, 04:04 PM
firemanpat29 is starting off with a positive reputation.
looks easy on a 2wd. 4wd the front shaft will not allow you to use that fancy 1/4" drive hex bit. A regular allen just fits. Wrap your arm over the drive shaft, unscrew from above and fuel will pour into drain(unsrcew from below and fuel will fill your armpit) Other than that great write up. My filters were way dirtier than yours, I had 20,000 miles on mine.
  #10 (permalink)
Old 02-12-2008, 04:52 PM
hdroadking05's Avatar
hdroadking05 is starting off with a positive reputation.
Does anyone know the torque specs for the filter caps and the drail plug?
__________________
2007 F250 6.0 PSD CC Lariat
4.5" Donahoe Racing Lift Kit
DirtLogic Steering Stabilizer
20x10 KMC Diesel Wheels
35x12.5 Toyo MTs
4" Magnaflow SS Turbo-back exhaust
EDGE Juice Platinum w/ Attitude
  #11 (permalink)
Old 02-12-2008, 05:46 PM
tippmann87's Avatar
tippmann87 is starting off with a positive reputation.
very nice write up
__________________
Support Law Enforcement; Donate to the National Law Enforcement Officers Memorial Fund (NLEOMF) http://www.nleomf.com/
"It's not how these officers died that made them Heroes; it is how they lived."
Former 2006 F250 Lariat PSD owner
Current truck:
2008 F150 XLT, CC, 4x4
  #12 (permalink)
Old 02-12-2008, 05:50 PM
DCSpecial's Avatar
FTE Sponsor
hdroadking,
I believe the torque specs are listed on the caps themselves.....and I think that the plug specs are right above it?
I can't remember for sure.
__________________
  #13 (permalink)
Old 02-12-2008, 06:03 PM
misterc is starting off with a positive reputation.
Fragrant casual ware
I have changed the fuel filter several times. This last time,a few weeks ago, I got fuel flow from the filter housing that wouldn't stop. I caught about a gallon in a pail and the rest dripping from the frame and crossmember took a bag and a half of kitty litter to soak up. And of course I had to lay in the puddle to get the new filter installed. My wife washed my t-shirt along with the rest of my t-shirts and socks and underware. I now have the wonderful fragrance of diesel fuel in all of my "casual ware".
The truck (2004 F350 CC DRW long bed) was in the shop all night and had not been started for at least 24 hours. Any idea why it decided to siphon the tank? Perhaps pressure in the tank from a temperature change? Should I open the fuel cap next time? Anyone have a similar experience?
  #14 (permalink)
Old 02-12-2008, 06:41 PM
COFC is starting off with a positive reputation.
Yes, in the past removing the filler cap released all the pressure in the tank, hence the pressure that forces the fuel OUT of the tank and into your face
  #15 (permalink)
Old 02-16-2008, 01:25 PM
slowmans is starting off with a positive reputation.
maybe im crazy but I changed my filters today and now when I turn the key on the fuel pump sounds loud? like I said maybe im going crazy but I dont remember it ever being loud enough to notice before...its not loud loud but it hums for about 30 seconds and then stops, when the truck is runnnig it isnt loud enough to hear?I have changed them 3 times on this truck and I dont remember hearing this before...
__________________
2006 F350 LARIAT 6.0 SUPERCAB 4X4 FX4
4"MBRP T-409 TURBO BACK COOL DUALS
EDELBROCK PERFORMER IAS SHOCKS
ACCUFAB POLISHED INTAKE ELBOW
KITTY IS AT THE VET!!!
305/65/18 BFG ALL-TERRAINS
DRINKING B-5 REGULARLY
08' REAR DIFF. COVER
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
