Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-04-2008, 06:25 AM
jswisc is starting off with a positive reputation.
The heads are different on the efi compared to the carb but the adapter bolts on where you remove your throttle-body. Then you bolt your carb to the adapter. You have to install a non-computer ignition system. I used the vacuum advance distributor from my original motor from an 87' f350. Since this motor went into the 87' f350 I used the engine wiring from the old engine. You will have to fab a bracket for your throttle linkage also. I haven't replaced my injectors. They still sit in the manifold. I had to cut two of them down in order to fit the carb. Very happy with the swap so far.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
