460 firing order HELP - Ford Truck Enthusiasts Forums
Old 07-13-1999, 01:08 AM
Kyle Hager
Guest
Posts: n/a
Does anyone know the firing order for a 1985 7.5L (460 cid) in a F250? Also, how are the cylinders numbered (i.e. clockwise, etc?)?
Old 07-13-1999, 10:37 AM
ray ray is offline
ray is starting off with a positive reputation.
1-5-4-2-6-3-7-8
Front of engine
5 1
6 2
7 3
8 4
Old 08-07-1999, 12:24 PM
Bruce Hartman
Guest
Posts: n/a
I have a Chilton for an 87 250 and the firing order for it is as follows. It may be of a help.
Dist rotation-Counterclockwise
From the front of the engine to the back:
left side: 1,2,3,4
right side: 5,6,7,8
dist placement is from the 12:30 or 1:00 postion
1-5-4-2-6-3-7-8
Hope this helps.
Old 08-08-1999, 07:22 PM
jwraft jwraft is offline
jwraft is starting off with a positive reputation.
Sorry Kyle don't know the firing order for the 460
, but I have a question for you. Do you have any information as to the H.P and torque on your 460?
I have a 1989 3/4 ton van with a 460 and I'm looking for the comparision between it and the new V10. the V10 has 265 H.P @ 4250 RPM and 405 lbs of torque @ 2750. Can you help? Thanks
John
Old 08-29-1999, 02:19 PM
calvin
Guest
Posts: n/a
460 Firing order. Points Gap Needed AgentOrange Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 01-19-2004 01:09 PM
Firing order? carpe_diem Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 08-01-2003 10:22 AM
What's the firing order & cylinder block numbers for 1995 460? Wanderlust Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-11-2003 12:18 PM
460 Firing Order Diagrams idunno Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 05-11-2003 09:28 PM
Firing order '87 460 gas lephant 1987 - 1996 F150 & Larger F-Series Trucks 6 02-26-2002 12:27 AM
Tags
1988, 1989, 1999, 460, 460firing, 75, 75l, cid, engine, f250, firing, ford, liter, order, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
