dove 460's - Ford Truck Enthusiasts Forums
dove 460's
Old 06-19-1999, 07:13 PM
tfs_460 tfs_460 is offline
tfs_460 is starting off with a positive reputation.
dove 460's
Does anyone know if there is a difference between the Dove A-Blocks? Ive found 3 and they are all different. One has an A with a searies of dots around it on the front right by the water pump and DOVE-A on the left side of the block, one has an A on top of a square on the right front by the water pump and it also says DOVE-A on the the left side of the block,and the last one has nothing by the water pump but still says DOVE-A on the side. Ive been told a DOVE-A block can be bored to .140 over but I dont know for sure . But if anyone knows let me know so I know witch of the three to buy if not all. Thanks
Old 06-22-1999, 08:32 AM
Deen Hylton
Guest
Posts: n/a
dove 460's
The only safe way to bore is to have a block sonic checked for thickness and core shift. I have bored two blocks .080 over but would not recommend this for everyday street use. A speed shop or machine shop should be able to give you sonic readings for $100 bucks or so. I went through a couple of SCJ blocks before I found one thick enough to safely bore to .080 over. Deen
Old 08-29-1999, 02:19 PM
calvin
Guest
Posts: n/a
dove 460's
most all early model 429 460 blocks (68) have a verry high nickle content so they are verry hard.i have a429 bored 80 over and stroked to a 514. i have never seen any block problems.mine is poured with morooso block filler.take one to a chevy man and tell him to bore it with a torque plate .....after he bores it ask him how it went.he will probably say something like Damn that block is hard,had to sharpen my cutters 4 or 5 times.and make 5 or 6 passes to get 80 over.i know because thats what i did.i dont believe that any production block can be bored that much.if you have any more questions you can email me. calvin love my ford truck.!!!!!)
Old 09-16-1999, 10:50 PM
calvin
Guest
Posts: n/a
dove 460's
1979 460 swap questions mightymoose95 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-24-2016 08:45 PM
79 f-150 460 swap mightymoose95 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 01-24-2016 02:32 PM
What size valves in a DOVE-A head? 41936 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 07-21-2015 07:31 PM
429/460 identification help with casting #'s d3racing Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 05-22-2003 08:44 AM
were all dove-c heads created equal jtlinn Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 04-30-2003 08:18 AM
Tags
080, 0ver, 460, 80, block, blockl, bore, bored, bores, difference, dove, engine, ford, safe, scj
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
