460 exhaust headers - Ford Truck Enthusiasts Forums
460 exhaust headers
Old 09-05-1999, 09:09 PM
Larry Skoglund
Guest
Posts: n/a
460 exhaust headers
I have a 460 F-250 4wd w/5sp manual trans. I pull trailers with this truck (race car) and would like to rebuild the exhaust. There is no manufacturer of headers for this truck! I can find tubes for automatics, but that has never interested me (I'm not over the hill yet). I guess it has to do with the clutch slave, but I can get no answer from builders, just "sorry, no application" Any ideas?
Old 09-07-1999, 08:27 AM
AWB AWB is offline
AWB is starting off with a positive reputation.
460 exhaust headers
-Have you tried Towers & Hardwood?
-Their number is (785)537-4100
If it has to do with a Ford they should know!
Old 09-16-1999, 09:50 PM
calvin
Guest
Posts: n/a
460 exhaust headers
you might try L&L products they make some that exit over the frame behind the shock in the fenderwell.i have a set on a f150 4x4.they cost 400.00.the only changes you will have to do is lower the radius arms or put a block under the spring to pick the frame up 3". nickel plated nice headers
Old 01-26-2000, 02:54 PM
chilly460 chilly460 is offline
chilly460 is starting off with a positive reputation.
460 exhaust headers
Headers or Old Logs sweetlou1 1967 - 1972 F-100 & Larger F-Series Trucks 14 10-23-2013 03:42 PM
Headers for a 1968 Ford F100 Truck with a 460 mlwhite77 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-08-2012 07:01 AM
1/4 Mile Times oricle General Automotive Discussion 11 04-18-2005 07:59 AM
1953 F-250 460 c-6 header help 53wa2fl 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-01-2005 02:35 PM
460 headers offroadfords Engine Swaps 5 03-26-2004 08:03 PM
Tags
1994, 460, exhaust, f250, ford, headers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
