Trick Flow 460 heads - Ford Truck Enthusiasts Forums
Old 02-26-2000, 11:27 PM
Neal Neal is offline
Neal is starting off with a positive reputation.
What kind of increase in horsepower can I realistically expect on a 460 with an edelbrock performer rpm intake and cam topped with a holley 850 double pumper by replacing stock heads with these which are advertised as direct replacements for super cobra jet heads? I haven't built the engine yet - I'm a dreamer, and a planner - but I will have true dual exhaust the whole way back with headers feeding 3" pipes, no cat. converters, and flowmasters. I'm on a bit of a budget, and $1800 isn't exactly pocket change. Does anyone have any recommendation for good heads that may be cheaper? I like the weight reduction of aluminum. Thanks a lot for everyone's help.
Neal
Old 02-27-2000, 09:11 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
>everyone's help.
> Neal
Neal, first off your Performer RPM manifold will not match with the SCJ heads, the port sizes are way bigger. Also you'll need a lot more cam to make use of the heads new breathablity...of course with more cam you need more compression, etc. If you have everything matched correctly expect to make a maximum of 600-625 HP with those heads.Those Cobra Jet heads will still be the limiting factor, they sign-off around 6,500 RPM. If you really want to "step-up" you need the "A460" heads, manifold, 1050 Dominator, etc. expect an easy 725 HP...I've spun a 514 to 7,600 RPM with no problems.
Old 02-27-2000, 04:54 PM
I appreciate the info. This will be a daily driver, and I'm on a 18 year old budget, so I need something that really moves when I hit the gas (got sideswiped recently in a Jeep because I didn't have the acceleration to get out of the way - it will never happen again), but I need something reliable that gets at least about 8 mpg and I can't afford to spend a fortune doing it. Should I just stick with the performer rpm kit or what? Are there better heads that cost less and would match this intake/cam or what? I'm basically looking for power in the 2000-6000rpm range. My only racing will be at the occasional redlight (gotta at least beat those new weak Z28s daddy bought his lil' unemployed rich boys). =) I'm basically new to this whole thing. My first car was a 90 mustang 5.0, but the engine was stock. I'm looking for 500-550hp if I can do it within my budget.
Old 02-27-2000, 08:30 PM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
If your an 18 year old with that kinda power, dont forget to budget for tires. I was 18 once, and its amazing how many tires a 302 can go through!
Nathan
Old 02-27-2000, 10:16 PM
Actually, I'll be 19 in two weeks, but the mentality's still the same. In the 'stang, I really wasn't that bad on tires. I had a few can't see anything but tire smoke all around you burnouts, but I enjoyed hurting my gas mileage with quick acceleration a lot more than sitting still and smelling burnt rubber. Fun, fun, fun! I kinda wish I still had that car - convertible and all, but the insurance just killed me.
Old 02-29-2000, 06:00 PM
Trail_Rider Trail_Rider is offline
Trail_Rider is starting off with a positive reputation.
I figure from the way you're talking you've already got the 460. If so I have no idea why you're short on power, unless the engine is shot. If that's the case I would suggest a good stock rebuild with some head work (port matching), and an RV cam . I had a stock rebuilt 390/4 speed/3:08 rear that would outrun and out pull anything I've ever seen and it always got a solid 10 mpg - loaded or empty. Just my 2c.
Trail Rider
Old 03-01-2000, 08:20 AM
(Front end noise) Turned Big Fix nateairman 1994.5 - 1997 7.3L Power Stroke Diesel 305 Yesterday 12:06 AM
'97 OBS Rear axle shackle flip or blocks? Neal 97 250 Offroad & 4x4 6 01-15-2010 10:27 PM
Spring codes ??? Neal 97 250 Excursion - King of SUVs 18 04-27-2009 11:35 AM
H2E installed w/pics !!! Neal 97 250 1994.5 - 1997 7.3L Power Stroke Diesel 50 09-24-2008 03:30 PM
460 balance question neals Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 02-21-2006 01:36 PM
Tags
460, 514, 6500rpm, cobra, edelbrock, flow, ford, head, heads, jet, kit, performance, performer, rebuild, rpm, super, trick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
