Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-11-2008, 10:29 PM
low54's Avatar
low54 low54 is offline
Garage is empty, add now
low54 is starting off with a positive reputation.
Cool 53 flathead v8 overheating question
Hey fella's I know this is a truck site which I have a '54 f-100. However, I just purchased a 53 Customline coupe with a flathead V8. The seller had no issues with overheating but as I was driving it home it started to overheat...significanly. I pulled the thermastat's, however, it continued to overheat and boil over...The seller stated he had put new water pumps in it...The raidiator hadn't been an issue...Do ya think It is? and needs to be rooted?...The car is miles away from its home unsafe and I'm frustrated as to what the heck is up! thanks fella's
  #2 (permalink)
Old 02-12-2008, 10:21 AM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
Radiator hoses collapsing. V belt slipping. Trailer it home.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
07 Edge SEL+ fwd
  #3 (permalink)
Old 02-12-2008, 10:52 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Sorry man - it happens. When it's all good this will be a memory that makes you grin. Hang in there!
Speed equals heat - how hard were you pushing it? Merlynr's comments are good, but be careful about tight Vbelts. They need 3/4" deflection or you'll burn up the wp, generator and fan bearings. Not as tight as modern stuff is right on.
But even then it shouldn't be overheating. Common causes are timing being retarded, block being full of sand/slag or the radiator plugged up. Previous owners have been known to lie thru their teeth....even after the sale
IF the nub that rubs on the dist cam wears off it acts to retard the timing also. Check your point gap first. They might not be opening enough .015 is what you want.
And, while I have done the same thing in your spot, they actually run cooler with the T stats in place if everything else is up to snuff. Drill a couple of 1/8" holes in the rim of the stats 180 deg apart - it allows the coolant to percolate back to the rad as it fills. It'll keep it from running hot while the stats open the first time.
  #4 (permalink)
Old 02-12-2008, 11:36 PM
low54's Avatar
Thanks for all the info, I'm trailering it back, Have a rad shop to flow test, I'll look at everthing else you suggested and post a report...again thanks
  #5 (permalink)
Old 02-14-2008, 07:46 PM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.
mine gives me fits like that from time to time yet and i cant quite put my finger on it . come good weather i'm gonna pull the radiator as it needs to have a leak soldered , and recored { yes i'd rather that than one of the new units } , and replace everything in the system again including a set of the new water pumps offered by some of advertiser / sponsors , and hope for the best . there isn't a dain thing wrong on the old girl and ran in the most extreme heat without issue then on the way home from the last show she boiled over again . dunno these ol' flatties can be particular !!!!!!!!!!
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!! if you don't have 2 or 3 broken fords / projects , then you just ain't right !!!!!!!!!!!!!!!!
  #6 (permalink)
Old 02-15-2008, 10:50 PM
low54's Avatar
well, I flushed out the rad and engine with a NAPA rad flush, put new 180 degree therms in new gaskets and walla! its stays under 190, and seems to be running great! okey< on with the next thing/s
  #7 (permalink)
Old 02-25-2008, 09:32 PM
leonharu's Avatar
leonharu leonharu is offline
leonharu is starting off with a positive reputation.
Which is way is advancing and retarding timing on flat head?
__________________
Russ
1952 F-1
1940 Ford Sedan
1973 F100 Ranger
1966 F100 Custom Cab
  #8 (permalink)
Old 02-25-2008, 10:10 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
turn opposite of the dist. rotation to advance, turn with dist. rotation to retard.
Tags
1953, 53, belt, cpe, customline, flat, flathead, flatheadfordv8overheating, ford, gap, head, oregon, overheating, points, set, timing, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
