Folks With the Carter P4070 "lift pump" - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-11-2008, 11:00 PM
rebelchevy02's Avatar
rebelchevy02 rebelchevy02 is offline
rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.
So who all is running it, for how long, and any issues? I went onto summitracing tonight, and it says its for a gas application, while the carter GP4389 is for diesel applications. I definetely want longevity, its a DD that gets 30-40k a year on it. Both seem to have the same info, just the GP4389 is techically for diesel use, and approximately $40 more. They both have the same picture aswell. So, whose got info?
Old 02-11-2008, 11:12 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
I have been running it since i put my fuel system in, back in july of 06. Still pumping like it should.
Old 02-12-2008, 10:52 AM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
I went with the 4594 instead of the 4070 because it had a slightly higher output pressure (couple of psi) and I couldn't get anyone to tell me that it would be a problem - exact same price, too.
Anyway, I've been running it since late summer and haven't had a single problem with it. I've got about 7-9K miles on it at this point.
Old 02-12-2008, 10:54 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Had mine too about the same amount of time as Kris. No problems. A little noisy even after adding vinyl gasket behind the mounting bracket.
Old 02-12-2008, 11:10 AM
Orezona's Avatar
Orezona Orezona is offline
Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.
I've been running it since last summer. No problems.
Old 02-12-2008, 12:12 PM
nhill2090 nhill2090 is offline
nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.
what exactly is the benefit of running the lift pump? conjunction with teh stock pump and pre pump filter to reduce strain on factory pump?
Old 02-12-2008, 12:17 PM
F250_'s Avatar
You got it, Nic. Really shouldn't be necessary if you have a healthy stock pump.
I chose to go that route myself because I over-engineer everything and had no data on the stocker (The Carter pump gave me some "suspenders" to go with my "belt"). Once I get my in-cab fuel pressure gauge hooked up, I'll get a better picture.
Old 02-12-2008, 12:32 PM
WMRiceman's Avatar
WMRiceman WMRiceman is offline
WMRiceman is gaining momentum as a positive member of FTE.
No problems here. I installed the Carter 4070 lift pump and a Carter 74221 high pressure pump. I shimmed the FPR to 68psi. Little noise but that lets you know it's working. I just installed a Fuel Pressure gauge in the cab, solid 68 psi all the time.
I have about 40k miles on the set up so far. I have the Racor 500 FG turbine filter between the tank and the 4070.
Just to make sure all was working, I took the hose off the intake side of the HP pump and the little 4070 sends out a nice solid stream of fuel.
Old 02-12-2008, 06:15 PM
Thanks for all the insight. Im glad to hear all the good about the 4070, Im just wondering if its worth the extra 40 for the GP4389, with a diesel rating, marine too I think it was. Glad to see some miles on the 4070 though, Id like it to last 50K+
Old 02-12-2008, 06:28 PM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
Almost 2 years and around 80,000 miles on the 4070, no problems. You will hear it , though.
Old 02-12-2008, 06:29 PM
F250_'s Avatar
It took me about 3-4 months to get to the point where I don't really notice mine any more... until I stop and listen for it.
Old 02-12-2008, 07:04 PM
Alpine6 Alpine6 is offline
Alpine6 is starting off with a positive reputation.
I've got about 14k on mine. No issues. You really do get use to the noise it makes. Very apparent when you first install, now I don't notice it unless I listen for it. I bought a second one to feed my aux tank to primary tank. Just need to hook it all up. TIME TIME TIME.
Old 02-12-2008, 08:09 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Quote:
Very true. Forgot to mention that last night Mike. The 4070 is a lot louder than the stock pump.
On Dave's (1996pwrstrk) truck we used a Holley red pump. It's quieter and has a higher output than the Carter.....but is also a good bit more expensive.
Old 02-12-2008, 11:42 PM
kupaa's Avatar
kupaa kupaa is offline
kupaa is gaining momentum as a positive member of FTE.
what about the fass pump,is it worth the extra $$$$ or will the carter do the same for cheaper??
Old 02-12-2008, 11:59 PM
SolidGround's Avatar
SolidGround SolidGround is offline
SolidGround is gaining momentum as a positive member of FTE.
AirDog.
And be done with it.
Aircraft cockpit waituntilthebeep 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-10-2016 06:11 PM
93 7.3 IDI Wont' Start Papa_Smurf Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 02-22-2016 11:44 PM
Aux Fuel Tank Pump & Filter Help jim48 6.7L Power Stroke Diesel 12 03-15-2011 09:40 PM
Carter vs. Bosch Fuel Pump Exchange Chzman 1999 - 2003 7.3L Power Stroke Diesel 8 02-25-2010 09:24 AM
Rat Rod, pics...... 52'F-3 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 09-24-2007 01:49 AM
Tags
2002, 4070, 4594, 73l, 74221, carter, electric, f250, f350, ford, fuel, gp4389, lift, p4070, pump, pumps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
