Folks With the Carter P4070 "lift pump" - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 09-18-2011, 09:26 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Quote:
Originally Posted by beanhead6D5 View Post
I am also running the same set up as Clay.I have had very good results.I am now looking at running duel factory pumps.With the filter set up I have I can run the pumps parallel to each other,not in a front to back setup.this way the fuel will flow through the filters the right way.
Anyone have a good stock pump they want to sell????
I would have given you one Brad, but Franko needed it worse than you. Well, sort of. IIRC, he's still running mine and his OEM is probably still ok due to finding the bad FPR and intank screens. Maybe he will pass it on to you.
  #32
Old 09-18-2011, 11:44 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Quote:
My OEM pump is good, Just let me know if you need it Brad. I'll be happy to pass it on.
  #33
Old 09-19-2011, 09:56 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
That would be great Frank! Yes I will take it.I just talked to Roland yesterday and we were brain storming on the twin pump set up.
I'll send you a Pm with my info.
  #34
Old 09-19-2011, 10:00 PM
Franko72's Avatar
Molon Labe
Glad I can help "pay it forward".
Thanks to Roland, he got the ball rolling.
  #35
Old 09-19-2011, 10:13 PM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
brad do a duel pump set up with each powered separate so if one goes down you can still get home
  #36
Old 09-20-2011, 06:59 PM
Quote:
You got it.A whole new service will be run for the other pump.I don't want to over load the fuse that runs the pump now.
  #37
Old 09-20-2011, 10:51 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
My Carter just gave up the ghost, I have a new stock FP, might have to run a duel set up also.......hmmmm
  #38
Old 09-20-2011, 11:03 PM
mueckster's Avatar
I ran a separate feed with relay and fuse to my lift pump when I was running it. I left the wiring there when the pump was removed and just took out the fuses. It would be easy to convert mine to "duals" if the need arises.
  #39
Old 09-20-2011, 11:36 PM
BadDogKuzz's Avatar
BadDogKuzz BadDogKuzz is offline
BadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud of
Quote:
Jeff how long did that carter last you ? And did it leave dead on the side of the road ? I had read somewhere that 1 model of Carter had a bypass if it quit ? Does that sound right?
  #40
Old 09-20-2011, 11:47 PM
BadDogKuzz's Avatar
Roland Did you use the power lead off stock pump to trigger the relay? And if you were to run dual stock pumps if one quit I don't think the stock pump has a bypass. So wouldn't it be trying to push or pull fuel though a stopped vane pump ? I would think if you were going to piggy back fuel pumps there would have to be some kind of bypass. I would think it would be the same even with the carter unless it has a bypass and I don't think the #4070 does. I am wondering if that pump left Jeff dead on the side of the road ?
  #41
Old 09-21-2011, 06:56 AM
mueckster's Avatar
Quote:
Ed, that is exactly what I did. I tapped into one of the power distribution boxes for the main power and mounted the relay to the fender using an existing bolt. I ran the supply feed to the fuel pump with a weatherpak mini fuse holder before it. The pump was grounded directly to the frame.
I thought about the restriction caused by a stopped pump before the main one and tested that scenario by removing the fuse. I had a pressure test gauge installed on my fuel bowl at the time. IDK the exact amount of pressure loss. It was pretty significant, but still allowed the engine to run well enough too limp home. I always carried a length of hose and some extra clamps with me to perform a "bypass" if the lift pump did fail. I also thought of using T's and ball valves to plumb a bypass around the pump. I figured that to be "overkill" and would be rarely used, so I just carried the hose.
  #42
Old 09-21-2011, 09:09 PM
BadDogKuzz's Avatar
Well it nice to know that you can still limp it home on 1 pump. I actually like your idea of "over kill" !! Then when it did happen to go out all you would have to do is hit the bypass valve. But where would get a diesel rated ball valve ? But you right it is easier to just carry some hose, barbs, and clamps as a back up. Well my whole game plan for my F350 has just went out the window. I need my carter 4070 for the generator in my motorhome. I think the 4070 runs about 4psi which is going to be perfect. But if it is any higher psi I might need to add a fuel pressure regulator. I have been stealing used parts from my truck for my motorhome. I hate to put new parts on something I only use a few times a year.
So now I am thinking I am going to try the pre filter without a lift pump. Which makes me wonder how long the stock pump will hang in there. Actually I need to get back working on the truck and finish the brake line and put the tank and pre filter in. I want to pull my boat out of the water for the season and then I can tear the truck apart and do it the way I want. Or should I say do what I can as I get the money.
  #43
Old 09-21-2011, 10:14 PM
WA.Ranger's Avatar
Man, it's lasted quite awhile, maybe 5 years and over 100k. It didn't leave me stranded. I was driving home from my parents house about 60 miles away when I noticed my fuel psi would drop to near zero when I hit the gas more than 1/4 throttle. The motor is what went out on mine, pulled the pump apart and it looked good.
  #44
Old 09-21-2011, 10:55 PM
BadDogKuzz's Avatar
Well I am glad you made it home OK !! So are you going to get another Carter or go with a different set up ? And since the motor went did you have it piggy backed off the stock pump or on a relay ?
  #45
Old 09-22-2011, 12:15 AM
WA.Ranger's Avatar
I had mine piggy backed, not the best way to go. It was a temporary set up that never got upgraded. I don't know how I'm going to go. I do have a brand new factory pump sitting on the shelf and liked the idea of running duals in parallel, but the Carter worked well.
Can I run '88 IDI GP's and harness on an '84 IDI? genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 08-03-2016 06:59 PM
Aircraft cockpit waituntilthebeep 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-10-2016 06:11 PM
93 7.3 IDI Wont' Start Papa_Smurf Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 02-22-2016 11:44 PM
Ford GP Questions The Bourg 1947 and Older Ford Trucks 6 07-08-2015 10:34 PM
Aux Fuel Tank Pump & Filter Help jim48 6.7L Power Stroke Diesel 12 03-15-2011 09:40 PM
Tags
2002, 4070, 4594, 73l, 74221, carter, electric, f250, f350, ford, fuel, gp4389, lift, p4070, pump, pumps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
