Crewcab Only Thread.
Old 05-07-2008, 05:43 PM
RNOVRIT's Avatar
RNOVRIT
RNOVRIT is offline
Not from the factory. All crewcab 4x4's are F250 shorts beds. The F-350's only came in long beds and 2wd only. After market companies did do 4x4 conversions but none came from the factory.
  #227
Old 05-07-2008, 05:52 PM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
thanx! got to love the crew cabs (message needed to be 10 letters long)
  #228
Old 05-13-2008, 02:57 PM
72togo's Avatar
72togo
72togo is offline
1978 crew 4x4 short box
I just picked up a retired fire dept pickup. Think i'll put it on ebay. Hope to get between 4500 and 5500. Is there a market for these. How do I post pictures here? email brandx@wtechlink.us
  #229
Old 05-14-2008, 12:20 AM
jhooch's Avatar
jhooch
jhooch is offline
Here in the California Bay Area, no market. Prineville, Oregon: different story. What it will fetch on Ebay has a lot to do with logistics. I.E. if the truck is worth $4500 someone on the other side of the country will not bid that high because they will have to factor the cost of shipping. Either flying out and driving it home or having it transported. The only way to find out for sure is to list it.
  #230
Old 05-14-2008, 09:04 AM
72togo's Avatar
72togo
72togo is offline
78 crew
Your right about listing it. I go to pick it up on thursday. Spend some time getting to know what I have so I can do repairs and detail it out. I'm guessing list it in two to three weeks`.
  #231
Old 05-17-2008, 02:14 PM
GONZO86's Avatar
GONZO86
GONZO86 is offline
gears
I just picked up a 1978 crew 4x4 with the 351m and d44frt
Is there a quick way to tell the gears in the frnt and rear end?
Also what is the best back spacing and rim size to run on the crews?
I have 6" sd spring waiting to install, so looing at some 36" tires but cant think of the best rim size (was thinking 16.5 x 12, not sure on backspaceing)
thanks
Rod
  #232
Old 05-17-2008, 07:12 PM
bendog's Avatar
bendog
bendog is offline
Just my opinion and experiance. 16.5 rims have no inner bead retainer, so if you air them down to go off road they will pop off the bead easier, also, tires are more expensive and harder to find a good selection of. The upside is, you can find lots of rims for cheap, for these very reasons. But the tires are more expensive.
  #233
Old 05-18-2008, 11:49 PM
jhooch's Avatar
jhooch
jhooch is offline
Just to add to what bendog was saying, I'd avoid 16.5's. They are on their way to extinction. As the last 16.5 molds wear out, manufacturers aren't going to invest money into retooling them. Go 16", 17", 18", or even 20". You're rim width will depend on what cross-section tire you're going to run. I.E. 12.50-13.50 would spec on 10" wide wheel as a general rule of thumb.
  #234
Old 05-19-2008, 01:04 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
I'll add another vote for AVOIDING 16.5" rims.
As far as the rim width - I run 315/75r16 tires on a 16x7" rim and 35x12.50r15 on 15x7" rims. You don't need super wide wheels to run these tires. The narrower wheels look WAY better IMO, and they protect the rim a bit more by ballooning out a bit in the sidewall. This is nice when driving where rocks and branches, etc. can nail the wheels
  #235
Old 05-19-2008, 09:09 AM
GONZO86's Avatar
GONZO86
GONZO86 is offline
so 16
so 16" rims will clear everything, always thought you couldnt clear the brakes with 16" that why they made the 16.5 stock.
thankss
  #236
Old 05-19-2008, 11:15 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
crazyredneckanyhow is offline
Yeah and some trucks came stock with split rims but ya dont see everyone runnin out and buyin those either
  #237
Old 05-19-2008, 01:19 PM
ChaseTruck754
thankss
I have "heard" of people having rubbing issues on the wheels/calipers with 16" rims, but I have never seen it myself/ The only thing I can think to cause this would be an overly thick cast aftermarket wheel. My 16" ford wheels are fine.
  #238
Old 05-20-2008, 12:48 AM
leadmic's Avatar
leadmic
leadmic is offline
16 will clear anthing on 73-79 ford 1/2-1ton.
Leadmic
  #239
Old 05-23-2008, 04:36 PM
72togo's Avatar
72togo
72togo is offline
  #240
Old 05-28-2008, 07:47 PM
crazyredneckanyhow
Quick Reply: Crewcab Only Thread.
