Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 03-05-2008, 02:11 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
I'm not a fan of the fiberglass either. With all the $/time they put into the custom molds for those fenders I wish they would have done something that kept the older lines. Still I think this setup look better than the F600 stuff. The front grill and how low the F600 fenders come down just kills it. There just needs to be some larger flare fenders that keep our grill and headlight setup, and since nothing is made that is why we're looking at making a larger flare fender and hood that keeps the old lines.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #92 (permalink)
Old 03-05-2008, 03:14 PM
greythorn3's Avatar
greythorn3 greythorn3 is offline
greythorn3 has a good reputation on FTE. greythorn3 has a good reputation on FTE. greythorn3 has a good reputation on FTE.
those tires look like crap!
  #93 (permalink)
Old 03-05-2008, 03:18 PM
1974 Ford F-250
In your opinion.
Those tires are the Kevlar sidewall (see 3 ribs in the sidewall) BFG race tires mounted on 17" Walker Evans beadlock rims. They put all the swamper BS crap to shame in terms of strength... and looks IMO.
Here's a writeup on the NON race version (no ribs in the sidewall = NO Kevlar plated sidewalls)
http://ford.off-road.com/ford/articl....jsp?id=224881
This truck is a purpose built truck for the desert, and therefore it's something the backwoods mud or trail guys would never understand. BUT they could learn a thing or 3 about quality of fabrication by looking at some of the desert trucks!!!!!
__________________
1970 Ford F250
  #94 (permalink)
Old 03-05-2008, 03:45 PM
greythorn3's Avatar
well it does look like you could get allot of highway millage out of them tires.. but good luck in a mudd hole.
RAy
  #95 (permalink)
Old 03-05-2008, 04:14 PM
1974 Ford F-250
For what little mud these DESERT trucks will see - it will be fine.
These things do in mud how mud tires do on the highway or anything else - "crappy, but they'll get you through it"
__________________
1970 Ford F250
  #96 (permalink)
Old 03-06-2008, 12:33 AM
dfreise dfreise is offline
dfreise is starting off with a positive reputation.
These would be cool on a cc. I guess these would be fallout doors, not suicide.
http://www.disappearing-car-door.com/#
  #97 (permalink)
Old 03-06-2008, 01:39 AM
greythorn3's Avatar
those are stupid, and would have all sorts of ice and slush in them in the first month of winter..
ray
  #98 (permalink)
Old 03-06-2008, 04:07 AM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE. roger dowty is gaining momentum as a positive member of FTE.
that is a ride!! baja stylin BIG freaking time!! Love that!
? please - need ASAP ASAP ASAP.
How does the c6 in a crew 4x4 with divorced transfer case differ from the c6 in a 1/2 ton with married transfer case????
It looks to me like they are similar...... confused! thanks
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #99 (permalink)
Old 03-06-2008, 05:40 AM
mando jake's Avatar
mando jake mando jake is offline
1988 Ford F-250
mando jake is starting off with a positive reputation.
I'd prolly get my arm cut off trying to roll down the window.
__________________
Leitchfield,ky 42754 FTE Kentucky Chapter member mando_jake@yahoo.com
88 F250 4x4 EFI 460 ZF5 4.10 gears limited slip.
  #100 (permalink)
Old 03-07-2008, 02:38 AM
Quote:
Originally Posted by ChaseTruck754
In your opinion.
http://ford.off-road.com/ford/article/articleDetail.jsp?id=224881
your absolutely right...the baja style rides have the most advanced go fast and go tough tech available for 4x4's.... The suspension systems are absolutely insane.
I LOVE that truck...I'm working on a tubular flatbed/baja style bed to fit my needs and hope to travel the southern baja someday in style!!!! thanks for the info
__________________
  #101 (permalink)
Old 03-07-2008, 07:21 AM
fomoco3904 fomoco3904 is offline
fomoco3904 is starting off with a positive reputation.
The C6 with married t-case will have to have the tailshaft housing changed at least. Other than that I think they are very similar. I'm not sure about the tailshaft - I seems like there is a good possibility that they may also be different. If so, that's a HUGE difference.
  #102 (permalink)
Old 03-07-2008, 04:36 PM
thanks...i know i can change out the tail housing...have to take the tranny apart to do it though. wish I had the cc to look at real close.
__________________
  #103 (permalink)
Old 03-07-2008, 05:22 PM
shoot4fun shoot4fun is offline
shoot4fun is starting off with a positive reputation.
Quote:
ray
Don't hold nuttin back now Ray. Say what's on yer mind!
__________________
Brad
'You can't fix stupid'
  #104 (permalink)
Old 03-08-2008, 12:22 PM
79Bronco5L 79Bronco5L is offline
79Bronco5L is starting off with a positive reputation.
New to this
Hey,
I just aquired a 75 F-250 Crew Cab, SB. 2wd. I've got a 79 Bronco parts truck from my last build, and wanted to swap the 4wd components under the 75, are the frames the same, will this even work?
  #105 (permalink)
Old 03-08-2008, 01:49 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is offline
78_f800crewcab4x4 is gaining momentum as a positive member of FTE. 78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 79Bronco5L
Hey,
the frames are different. Personally i wouldnt put the d44 under the f250, its a little small for a heavy beast crew cab. find a d60 to swap in. Any way you look at it, the suspension will have to be custom, but you may be able to use the origional f250 coil towers. Someone on here has done that before.
__________________
1978 F600 Bronco 4 door "Centurion"
1958 F700 next "Centurion" project
1973 F350 Crew Cab Special, 460 all race
2002 Excursion Limited 4x4 7.3
Please help them:
http://www.lionconservation.org/index.html
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
