You will have to fab a transfer case shifter mount if you use a non-highboy transmission. The shifter mounts are on the transmission case at the tail. I remember that being a problem for me at one time. My '76 has a 460/C6 from a '73 Lincoln, so there was obviously no provision for a transfer case shifter on it!
I've heard that the '67-'72 crew body fitted to a '73-79 crew chassis doesn't fit exactly, and that you have to fudge the gap between the cab and frame. Has anyone had experience with this? I know that the frame rails are wider on my '77 so I'll have to drill new holes in the bed, but this gap might look goofy, I'm afraid.
67-72 crewcab short = 149" 73-79"" = 150"
not much to fill a 1" gap. Wide frame = rear tank HMMMM
That 400 with Aussie heads and roller cam sounds like a motor for a lightweight car or a 2wd pickup, definitely not for a heavy Bronco or crewcab.
Go with the big block's torque and don't build it for rpms.
I got a CC question... I'm taking a late '70s (I think '78 or 9)CC body off, and going to install a regular cab ('78) in its place. (Don't get yer panties in a wad! I'm doing this to acquire the CC body!) Is there a difference in frame width on these years? (I don't have the CC home yet, so I can't put a tape to it. All this talk of frame widths makes me wonder. Not going to keep me from doing it, I'd just like to know ahead of time, so I can prepare. The CC is going to be mounted on a totally different frame, so that'll be another game all together. I just need to know for the reg. cab mounting purposes.
Is it a 2wd or 4wd? Itf its a 4wd the frames are like a highboy up to 77.5. 77.5 adn up are jus like the regular cab f-250 4wds. If its a 2wd the frame is like the highboys no matter what year. The frame will get narrower after the cab. Why Ford did this i have no idea but they did.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
The crews rear mounts are on the outside of the frame. They dont have the crossmember setup like a reg cab.
__________________
__________________ Have you flown a ford lately? 1938 Ford Pickup = hot rod
1970 Ford F250 long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cabthread in "motor swap" forum 1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
Hey guys just a heads up. Every once and awhile i wil compile a list of post numbers that dont really make anythin and have them deleted by the great lxman1. Not picking on anyone ingeneral just need to keep it clean and techy so it wont get the boot.
__________________
I dont like that front and back fiberglass. newer stuff looks like crap
__________________
Has anyone ever used a new skin for front doors on the rear? I imagine there would be some fabrication at the front edge of the rear door to make the front skins match.
