Crewcab Only Thread. - Page 55 - Ford Truck Enthusiasts Forums
  #811
Old 12-31-2009, 12:47 AM
pvillebo pvillebo is offline
pvillebo is starting off with a positive reputation.
Do you have a 89 F350 or 79 F350 Truckcentral?
  #812
Old 12-31-2009, 01:05 AM
TruckCentral's Avatar
TruckCentral TruckCentral is offline
TruckCentral is starting off with a positive reputation.
I have a 96 F250 standard cab and an 1989 F350 Crewcab Dually...
  #813
Old 12-31-2009, 01:28 AM
The reason I asked is because you are in the 1973-1979 F100 and larger F-Series trucks > crewcab only thread.You got the crewcab part right now get the years right and you will have a better chance of getting your question answered.
  #814
Old 12-31-2009, 01:57 AM
Well it dont hurt to ask.. didnt notice the yr part.. just raised a brow when i seen the crewcab part... explains why everyone is sportin some sweet oldies...LOL
  #815
Old 01-01-2010, 02:45 PM
Well OK I am back. Seems to be alot going on here. I have looked elsewere for any threads for newer crewcabs to no avail. So. I am asking anyone know of such a thread? Perhaps I over looked it. I am looking for what you all seem to have here but for a newer crewcab..but older ones would be ok too...
TruckCentral
  #816
Old 01-06-2010, 07:25 AM
kentuckycrew kentuckycrew is offline
kentuckycrew is starting off with a positive reputation.
Ok i know some of yall was making custom headliners (and im way to lazy to look back through all the post to remember who). Anyway has anyone got pics of how they turned out?, measurements?,tips?
Thanks
  #817
Old 01-06-2010, 03:14 PM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
Ranger429 made one....
  #818
Old 01-08-2010, 06:48 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
Hey F800 you got a 460 in that silver monster? What kind of speeds you run on the interstate?
  #819
Old 01-11-2010, 08:49 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Quote:
Thanks
I never updated this thread.
Final mock up of the headliner.
I ground out the spot welds on the original center divider and removed that. I also added the flat plate for the dome light mount.
Fitted for size.
Dome light installed, still need to run wire.
Testing the glue on the headliner. I thought I'd try it without the padding for better adhesion but it looks much better with the padding. The countertop glue holds excellent and I have no fear of it seperating down the road.
Test fitting the leather.
Black leather with some 1/2" padding. I have it all glued in place but don't have a finished picture yet. Still haven't installed it as I'm waiting on paint.
  #820
Old 01-11-2010, 08:57 PM
thanks, I do believe that it is gonna look great. What is the stuff called that you used? You wouldnt happen to know the measurments would you?
  #821
Old 01-11-2010, 09:02 PM
It was 1/16" thick formica countertop. I didn't pull measurements, just laid the old headliner on it and drew the outline and hit it with a router then a belt sander for final touch up. I probably installed and took it out 3 or 4 times making minor size adjustments for fit. It really requires 2 people to put it up, formice will crack easily if you let it hang freely. On the other hand thought is flexible enough to follow the contour but yet strong enough to hold it's shape when up.
I put the center light in for 2 reasons:
1) Ford should of done this to begin with
2) It holds the center of the headliner nice and tight to the inner roof line
  #822
Old 01-11-2010, 09:04 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
For #2 on thew above - did you screw the light into the "crossmember" that goes across the roof?
And do you know if they make replacement lenses for those lights? I grabbed one out of the 86 bronco I had in the shop but light plastic lens is destroyed.
  #823
Old 01-11-2010, 09:06 PM
I screwed it into the plate I welded in. Turned out to be perfect for a driver viewing light. Yes I've seen lenses seperately before.
  #824
Old 01-12-2010, 12:38 AM
andyort's Avatar
andyort andyort is offline
andyort is starting off with a positive reputation.
1978 F250 Crew
Im new FTE I would like to know what the best type of drip rail sealer is. I am starting my restore next week. There is no rust on this thing and i am putting all the best parts and do dads i can find on it. Any advice. Im not sure i posted on the right page if im not would you guys give send me to the right one.
  #825
Old 01-22-2010, 02:47 AM
Cowboynando Cowboynando is offline
Cowboynando is starting off with a positive reputation.
Cool Radiator Mounts
Ok, so I bought a '73 CC a while back and have been using a '78 F-150 for a donor. Well the previous owner has Hacked the h*ll out of the truck,
Specifically the front end. The previous owner had put a 6.9 diesel in it, anyway at the moment I am trying to put the radiator mount (front clip) in the '73 from the '78 but it apears that he cut the frame and welded in lower mounts to the outside of the frame....so the front clip wont match up. I believe this was done in part because he used a different steering gear box. It's a mess! Does anyone have pic's of what it should look like? Are the lower mounts for the radiator support centered in the front part of the frame? It looks to me like they were, but the previous owner torched the frame out. I think I am going to have to box the frame, and start over. Any thoughts?
1977 crewcab cummins build 77_crew 1973 - 1979 F-100 & Larger F-Series Trucks 527 12-23-2016 08:48 AM
standard cab and crew cab front mount location spacing Earnie Rosenow 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-10-2016 12:40 PM
65 thru 72 Crew Cab Frame Questions James_Western_Canada 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-08-2016 08:50 PM
Ordering a truck. How much below invoice can I expect? whalerron 1999 to 2016 Super Duty 18 01-18-2016 04:18 PM
1978 Ford Crew Cummins Swap Higbean Engine Swaps 244 11-29-2015 05:21 PM
Tags
1970, 1973, 78, 8, 90s, bed, cab, crew, doors, f250, f350, ford, lowered, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
