Good to see you here - I'm sure you will find some useful info if you search around a bit
Can't believe I never knew about this place, it's like an abandoned junk-yard. That's a complement! Now crazy thought's of another crewcab 7.3 IDI auto are bouncing around my noggin. Something for fuel milage you know?
I'm going to post this here because there has been a lot of talk on headliners recently. I am going to use a single piece of formica countertop. It is about 1/16" thick so it is very flexible. I'll update once I find the right material that I'll use to cover it.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
Thanks Scott for the picture of the headliner. That seems like a logical solution to the old two part headliner and get rid of the plastic middle strip. What type of material are you going to cover it with? How did you get the exact shape onto the formica - use your old headliners as a pattern?
__________________
1996 F150 4x4, 351, auto, LB, K&N Filtercharger, "Silver Bullet"
1978 F250 CC, sb, 4x4 "in the works"
Old headliner as a pattern and added a 1 1/2" to make up for the gap in the middle. The countertop guy (my next door neighbor at the shop) was nice enough to use his router and belt sander to dial it in. I'm going to use 1/4-3/8" padding and then the material, probably vinyl. Have to wait till I find it at the store first.
__________________
Thanks for the idea Ranger.That shouldn't be a problem for me seeing that my Pop has been building countertops for 37 years.I kinda fault myself for not thinking of that earlier.
Well heres the latest. I cut 12" out of an 8ft bed. Not the best pic but its to heavy to push in and out of the garage on my own. Bob ill be sending you an email soon about the other frame.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
