Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #691 (permalink)
Old 10-03-2009, 11:22 AM
pvillebo pvillebo is offline
pvillebo is starting off with a positive reputation.
That does look good Todd.But from looking at how much of the roof your headliner covers looks like the last guy has screwed that up for me to.I'm not positive,I will have to look again,but I don't think I have enough frame to do the whole roof.I like how you added that extra light to.Where or what did you wire it in at.You can never go wrong with more light.
  #692 (permalink)
Old 10-03-2009, 11:57 AM
After looking at it,there is enough there to do the whole roof but one piece is broke and the molding that goes across the middle is only about 2/3 as long as it needs to be.But I will figure something out.
  #693 (permalink)
Old 10-03-2009, 12:00 PM
ranger429 ranger429 is offline
ranger429 is gaining momentum as a positive member of FTE. ranger429 is gaining momentum as a positive member of FTE.
The light can be wired right to the door jamb switch or the headlight switch.
My center plastic piece is pretty busted up and I've thought about using a piece of 1/2" wide aluminum strip there or nothing. Depends how sturdy the board is once in place.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
Vote in the FTE final round: http://www.ford-trucks.com/forums/90...nal-round.html
  #694 (permalink)
Old 10-03-2009, 12:28 PM
Ranger,have you posted any more pics of your crew since you posted the ones in July?I want to get my done so bad I can taste it.My problem is I don't have no room or a shop to work on it so I am trying to get everything lined up so when I start on it I won't have everything strung all over the place but for a little while( thats the plan anyway).
  #695 (permalink)
Old 10-03-2009, 12:43 PM
Yes there is a thread in this section on my build. Crewcab restoration or something like that, I'n on a blackberry so I can't get the link.
__________________
  #696 (permalink)
Old 10-03-2009, 01:55 PM
Well after making a trip to Lowes and measuring the OE headliner I don't know if I'll be able to find a piece big enough to make it in one piece. Measurements for the OE headliner are 61" by 53 3/4", a little to big for a 4x8 piece.
__________________
  #697 (permalink)
Old 10-03-2009, 10:34 PM
Todds79's Avatar
Todds79 Todds79 is offline
Todds79 is gaining momentum as a positive member of FTE.
ranger429,
I had thought about the aluminum strip also, but the orginal worked back. I had to use some small self tapping screws on the edges where the two pieces meet, just in the curve to hold it up tight. Then I was able to use the original strip. I used one 4x8 sheet--cut the rear out first, then used the end for the front. It was not quite long enough, so I joined some of the scrap to make a piece long enough for the front. The patch was a section about 5" wide glued to the topside. From the bottom you can't tell it, and after covering, you never knew it was glued together.
The dome light was easy, just tapped into the wire going to the rear light. I also ran a fused wire that is hot all the time for the map lights in the same fixture.
__________________
Todd
79 F100 Lariat 351w/C6
76 F250 Crew 390/NP435/Dana24/
Dana60/60
85 F250 429/C6/D44/D70 5.79/300ft Mud Racer/Dirt Drag
79 F150 Lariat 460/C6
  #698 (permalink)
Old 10-03-2009, 10:37 PM
My original trim piece in the center is pretty cracked up. It would work if I had to do 2 seperate headliner pieces but I figured one solid piece would be better and then the strip wouldn't be necessary. I don't know if I'll be able to find a piece of board big enough to do it in one piece.
__________________
  #699 (permalink)
Old 10-04-2009, 12:56 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is online now
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Like all - my center piece is trash too. When I do the aluminum one I plan to bead roll it with an "offset" pattern to give the thing (only like .032 thick) some rigidity. I just left one piece of the aluminum longger than the other and due to the "offset" type bead roll in the thing I can overlap them easily.
I have the aluminum and have had the pattern traced on them (my front headliner was good - back was deteriorating fast) for almost a year now. One of these days I'll get to working on that part of the project again
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #700 (permalink)
Old 10-04-2009, 04:19 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
Ranger im sure you can get alum. in 5x10 sheets if youd want to go that way. Im not sure what im goin to do.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #701 (permalink)
Old 10-04-2009, 04:39 PM
That might be another option, it might look pretty good up there as well.
__________________
  #702 (permalink)
Old 10-04-2009, 04:42 PM
Id bead roll it like steve is sayin. It would look good
__________________
  #703 (permalink)
Old 10-05-2009, 11:35 AM
pruitt's Avatar
pruitt pruitt is offline
pruitt is starting off with a positive reputation.
new crew cab owner, picked this one up a couple weeks ago, was building a supercab and decided i want a crew so this is the start now to get it all together. 1979 4x4 44 front 60 rear, 400M c6 205, A/C. setting in the garage for this ride is a 95 12valve cummins and nv4500 and a set of dana 60's from another 79 i have.
  #704 (permalink)
Old 10-05-2009, 12:53 PM
Looks like a great start. I found that formica countertop comes in a 60” wide piece and is only a 1/16” thick. I got a sample piece I'm going to try out
__________________
  #705 (permalink)
Old 10-05-2009, 01:12 PM
1974 Ford F-250
nice truck Pruitt. I know Dave (crazyredneck..) was looking at that one too. Seems like a good start!
__________________
1970 Ford F250
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
