Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #586 (permalink)
Old 08-09-2009, 12:05 AM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
Your front door and back door hinges are the same is what you are saying...correct?
__________________
1979 F-350 4x4 Dana 60's Front And Rear
1978 F-250 Supercab 4x4 w/Dana 60's front and rear
1978 F-250 4x4 Crew Cab Waiting For A Cummins
1976 F-250 Highboy Tow Truck
1979 F-150 4x4 Shorty
Way Too Many Trucks to list 29 Total So Far!!
  #587 (permalink)
Old 08-09-2009, 01:55 AM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
yes i can dubble check and take pics if you want...
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #588 (permalink)
Old 08-09-2009, 02:26 AM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Yes to all of the above.
Yes 73-79 crews use 67-72 style door hinges on the BACK doors.
And yes - Brady's and all other 67-72 crews have the same door hinges (the 67-72 style) both front and rear
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #589 (permalink)
Old 08-09-2009, 02:33 AM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
I Like how he says "I am currently parting out a nice '75 F-100 CrewCab 4x4 HighBoy"
That's funny!
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
  #590 (permalink)
Old 08-09-2009, 09:31 AM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
bought this crew..a 77 4x4 long bed...not made that way, but stretched some time ago, has a/c manual trans, lp d60 and d60 ls, I am adding a 55 gal custom made stainless aft tank to fit between the narrower rails, along w/ the fwd. aux tank, as long as it will fit???, the 78/79 pwr. steering upgrade the custom long bed w/ the dual sid boxes and dual tank doors along w/ any other 'goodies' that I may p/u along the way. The cab had some rust over the drip rails and I had cut up 2 s/c roofs for the repair ..but I located a SWEET 74 crew cab body that was redone, but nothing else was useful, so it all sat idle until yesterday 08/08/09, now I will join the others who re-did their crews, also planning on putting either por 15 or rust bullet on the frame and under body panels...any one better than the other???
started w/ this
sold the dual wheel fenders, never going to need the duallie set up.
moved to this...
to this on 08/08/09...
this is the donor 74 crew cab body...I am filling in where the skylight was cut out and looking into adding rear shoulder harnesses...also a factory a/c cab, manual trans set up..still comtemplating switching to automatic, have trans. available, willl probably have to shorten the d/s between the divorced transfer case...this also came w/ front diff skid plate and transfer case skid plate, warn 8,000 lbs winch w/ bumper and grille guard and the custom fuel tank
this is the custom long bed that is going on the crew cab..had factory tool boxes installed on both sides, along w/ the dual tank doors, will probably be installing the factory tie-downs, still kicking around the idea of installing the race track trim, I would have to custumize the d/s lower trim near the tool box...ugh!!
so the saga begins!!!
NOTE....Scott you are given some credit for starting the fire
  #591 (permalink)
Old 08-09-2009, 09:42 AM
78f250lj's Avatar
78f250lj 78f250lj is offline
78f250lj is starting off with a positive reputation.
Nice project you have going there! I will get some pics up soon of mine.
  #592 (permalink)
Old 08-09-2009, 09:46 AM
Thanks, looking fwd. to seeing the pics of your crew.
  #593 (permalink)
Old 08-09-2009, 12:07 PM
you ask and you shall recive....
Front
rear
__________________
SoCal FTE Member
  #594 (permalink)
Old 08-09-2009, 12:13 PM
ranger429 ranger429 is online now
ranger429 is gaining momentum as a positive member of FTE. ranger429 is gaining momentum as a positive member of FTE.
Quote:
Yeah because I know you have been talking about it since my Bronco resto started and now I'm already on to the CC.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
  #595 (permalink)
Old 08-09-2009, 01:25 PM
it was a ssllloooowwww starting flame that just IGNITED!
  #596 (permalink)
Old 08-09-2009, 01:58 PM
Race Track Trim
Hey lostinfords...you wanna sell that crew cab specific racetrack trim? Let me know...LOL
__________________
  #597 (permalink)
Old 08-09-2009, 02:01 PM
Hinges
Thanks Brady!!! I love finding out all the oddball parts ford used to put these trucks together...lol...especially since it was mostly factory parts from one vehicle or another!!!
__________________
  #598 (permalink)
Old 08-09-2009, 02:26 PM
Quote:
Back of the line, I've been pestering him for a while on it.
__________________
  #599 (permalink)
Old 08-09-2009, 03:49 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
Ive got a 78 bronc that woud be a good donor for a 4 door bronco. Just throwin that out there incase anyone is lookin.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #600 (permalink)
Old 08-09-2009, 07:03 PM
1974 Ford F-250
no one but you is crazy enough to think about spending that much time on one of these Dave - hahaha.
Besides - I thought you were gonna turn your truck into a 4 door bronco
__________________
1970 Ford F250
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
