Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #481 (permalink)
Old 03-05-2009, 03:11 AM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE. roger dowty is gaining momentum as a positive member of FTE.
an update for those on this thread that don't know me....an update. I will post pics in the next couple of days. I've been sitting on a 75 cc 4by for a few months....6 other notable projects going. I purchased the truck for 900. The cab is nearly pristine with beginnings of rust on pass floorboard and a small amount on a door jam. Top is great w/o any sign of rust to include dip rails. Bed is horrible....rusted out good.
I just bought a 390 attached to the proper c-6. Both in working condition i've been told. 390 shows decent compression 133-139#. i'll rip er down before i put it in and replace bearings etc as i have another std bore 390 with good heads to build proper and i'd prefer standard tranny with over/underdrive. I just saw a local missoulian who put a nice 79 cc from a 2wd on a 4x4 frame...did a great job. Has a 460 in it, loaded air etc.
any suggestions appreciated.
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #482 (permalink)
Old 03-12-2009, 04:54 PM
therealulysses's Avatar
therealulysses therealulysses is offline
therealulysses is starting off with a positive reputation.
Greetings. I just came in here to find out how to fix my differential and now I'm worried about rust! It has a few specks where there are paint chips around the doors etc and it sounds like I need to look under the headliner. It's a 1978 F350 2wd Crew Cab "Custom" with a 351 modified, 2bl carb, C6 trans (I think) and I'm not sure which differential but it's full floating so I guess a Dana 60? It's pretty much all stock except it had different wheels on the front and back when I got it (3rd owner) so now the wheels all match. I've had it about 10 years and I've been driving it all this time (well, not all the time) and it has about 96,000 miles on it. It has developed a loud hum/whine in the drivetrain which from what I've read is likely the differential. Now I guess I'll go back and read the FAQs. And look for rust. Cya.
__________________
In California, the Totalitarianism State.
  #483 (permalink)
Old 03-16-2009, 07:56 PM
malcolmm malcolmm is offline
malcolmm is starting off with a positive reputation.
Are cc windshields the same as other trucks? My 76 needs a new one really bad, I dont know if they are diffrent because of the roofs being hand made. Also where can we get full rubber mats for your floors? I am going to be using the truck to pull my boat with and want it to be easy to clean out. Thanks for all the help guys!!!
  #484 (permalink)
Old 03-16-2009, 08:00 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is online now
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Quote:
The crew windshields are the same as the others. The cab is just a standard cab that was taken off the assembly line and stretched.
Not sure what to tell you on the rubber type floor mat thing.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #485 (permalink)
Old 03-16-2009, 08:13 PM
Yea I might have to put down bed linner down, but that sucks in the winter. Its harder to keep it warm. I all most forgot, Where can we get after market a/c parts for dealer installed a/c? Some one took all of the parts out of the truck for it and I want to replace it. Thanks
  #486 (permalink)
Old 03-21-2009, 11:37 PM
'75 crew cab driveline manual tranny swap
i'm looking at a np 435 out of a 72 2wd f100. Or a t-18 out of a '69 f250.
The crew came with a c6. I'm resigned to having to have a driveline made from tranny to 205 case. Are there other options? ie did they come with either tranny stock so i could get a scrapyard driveline.
Also...see any issue with using pedals etc from the earlier trucks since mine is a '75.
thanks
__________________
  #487 (permalink)
Old 03-23-2009, 06:40 PM
s.squared-39 s.squared-39 is offline
s.squared-39 is starting off with a positive reputation.
There are a few places around. Like at JBG. There are a few different colors. I intend to get one but haven't yet. Most of the feedback on them is good.
Vinyl Floor Cover, Crew Cab 4x4 Pick-up, Black
__________________
Scott
1975 F-250 Crew Cab 4x4
Regina, SK
Chapter Member Saskatchewan/Manitoba
"build a man a fire and he stays warm for a few hours, light a man on fire and he stays warm for the rest of his life"
  #488 (permalink)
Old 03-25-2009, 02:56 AM
Thanks for the link!!!
  #489 (permalink)
Old 03-26-2009, 01:50 AM
2WD to 4WD
It looks like I will be doing a 4wd conversion to the crew cab. I am going to be buying a 1975 f250 highboy That has every thing I need to do the swap. Even has a rebuilt 390 with an auto. That make it the best deal for me.
  #490 (permalink)
Old 04-01-2009, 11:25 AM
4diggen5 4diggen5 is offline
4diggen5 is starting off with a positive reputation.
I just purchase a crew cab it has a highboy frame with a 390 np 435 divorced np 205 but the title and cab says 78 and it has the late 78 and 79 head lights and grill in it so what the heck is it . it also is a factory short box and i cant find any place on the frame that has been altered.?.
  #491 (permalink)
Old 04-01-2009, 11:27 AM
I also need doors or skins for the rear doors they are not rusted just dented does anyone know where to find these parts? I have a super cab that I use as a mud truck and the panels are easy to find but i cant find ant repoped crew cab parts.
  #492 (permalink)
Old 04-01-2009, 11:44 AM
1974 Ford F-250
Quote:
No one reproduces the read doors for the crew cabs. Time to junk yard hunt and/or pay through the teeth - they are getting hard to find...
__________________
1970 Ford F250
  #493 (permalink)
Old 04-01-2009, 05:09 PM
ranger429 ranger429 is offline
ranger429 is gaining momentum as a positive member of FTE. ranger429 is gaining momentum as a positive member of FTE.
It's quite easy to change the cab or door vin tag to correspond with a 78 title. It's also very easy to put a 78 grille shell on an earlier model. Check the upper frame rail on the passenger side for the vin # of the frame.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
Vote in the FTE final round: http://www.ford-trucks.com/forums/90...nal-round.html
  #494 (permalink)
Old 04-01-2009, 06:57 PM
jacfordf-250 jacfordf-250 is online now
jacfordf-250 is starting off with a positive reputation.
queston
Quote:
Originally Posted by crazyredneckanyhow View Post
I love POR 15. Its expensive but its worth it. My crew has a couple pin holes on teh passenger side that i have to get on this summer.
what is por 15.?
  #495 (permalink)
Old 04-01-2009, 07:22 PM
1974 Ford F-250
specialty rust prevention paint
__________________
1970 Ford F250
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
