Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #406 (permalink)
Old 12-06-2008, 08:15 AM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
1973 crewcab....email sent w/ pics and suggestion of what to look for, linkage oof for door or vacuum off of actuator, parts are seen in pics from link that Infoford set up to change heater core/blower fan, it is really helpful!
  #407 (permalink)
Old 12-06-2008, 07:42 PM
1973CrewCab 1973CrewCab is offline
1973CrewCab is starting off with a positive reputation.
Quote:
thanks for the help, i looked inside the dash and the ac/heater box and under the hood, and everything looks like is working like it is supposed to. that is why i am confused. i have no vacuum leaks and all the vacuum actuators are working good, and the air mixture door is controlled by a cable and seems to be working properly. if you or anyone else has any other ideas, i am all ears. thanks again.
  #408 (permalink)
Old 12-06-2008, 08:19 PM
Do you hear the door open and close when you move the selector??
  #409 (permalink)
Old 12-06-2008, 09:01 PM
yeah, when i move the temp control i can hear the air mixture door move if i have the truck turned off. and with the truck running i can hear and see the vacuum actuators on the other doors (for directing air to floor,panel,defrost) moving and working normally. the heater blows hot air great when the truck is sitting still but the air coming out of the vents (floor, panel, and defrost) gets cooler and in 2 or 3 minutes the air coming out is the same temperature as the outside air. i thought maybe the thermostat was opening early but i added a mechanical temp guage and once the truck warms up it stays at 185-190 degrees. i am usually a very good mechanic (mostly international diesels but also perty much any old gas engine) too but this is the first time i have been stumped like this.
  #410 (permalink)
Old 12-07-2008, 06:09 AM
If it isn't the moving fwd. of the truck that is allowing/forcing the cold air in maybe the heater core is losing it's warm water supply, ie; if you are getting hot water sitting idle and then when you get under way the flow is restricted, thus it cools down and maybe your mechanical gauge does not rect to the temp. drop tha fast. I would try 2 things, #1 physically get an idea of how warm your 2 heater hoses are sitting still, drive and when the cab temp. cools down, check to see if both are still the same temp.???? is the heater control valve open???, you could bypass that to rule out it being restricted internally.#2 determine if the blend door needs vacuum to be open, or closed and whichever it is, make it stay open, I would make sure it is open, disconnect the vacuum and secure the door open at the actuator, I once had a truck that pulled too much vacuum and it changed what was vacuum operated, I had too set up my vacuum ports correctly, I don't know if that makes any sense or not.
  #411 (permalink)
Old 12-07-2008, 08:40 AM
pauls painting's Avatar
pauls painting pauls painting is offline
pauls painting is starting off with a positive reputation.
well i have the cab off and will be cleaning up the frame this week. whats the best frame paint to use? also whats the best 2wd suspension parts to use? thanks
__________________
1977 f250 4x4 460 c6
1977 f350 2wd 400 c6 crew cab (project in progress)
2004 f150 fx4 screw 5.4 300hp
  #412 (permalink)
Old 12-07-2008, 09:13 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
As far as frame paint id use POR15. Its a rust preventer and ive used it. Works great. Only thing is that UV rays break it down. I just covered what i did with black rustoleum.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #413 (permalink)
Old 12-07-2008, 05:20 PM
CkBed CkBed is offline
CkBed is starting off with a positive reputation.
Thought I'd throw my truck in here.
75F250 CCSB, 2wd, WAS a 360(stroked to 390)/4 Speed. Gonna be swapping to a Dana 60 4x4 up front, and adding a 6.0l Powerstroke/Auto in the future. Gonna be pulling the body off, and starting frame up. Lil rust here and there, but its in decent shape. I've got two 78 parts trucks for some lil body panels and stuff
  #414 (permalink)
Old 12-08-2008, 03:22 PM
Burg460 Burg460 is offline
Burg460 is starting off with a positive reputation.
Wow, I am a blonde! I have been on here for years and just noticed this thread a couple weeks ago, been trying to read through everything. LOL
Just thought I would chime in...
I have 2 and a half crew cabs!
A 73 F-350 Crew Cab Camper Special 390/NP435 - converted over to 4x4 - just about done with conversion
A 77 F-250 Crew Cab 4x4 Short bed 351/NP435/205
A cab and rear doors from a 75 F-350 (thats the half!) Using this cab for my 73 as it is rusty. I have quite a few pics, need to update my gallery, will do that one of these days.
Hopefully I can get in on the fun a little more! Looks like we got some sweet CC's in here!
__________________
1995 F-150 Super Cab 4x4
1973 F-350 Crew Cab 4x4 - aka Slimer
1975 F-250 Super Cab 2x4
1977 F-250 Crew Cab 4x4
1978 F-150 Regular Cab 4x4
I have a few trucks...Some not listed..
  #415 (permalink)
Old 12-08-2008, 11:46 PM
Burg460, does your crew cab camper special have the cast aluminum emblems/badges that say "crew cab special" on them? there was a guy who psoted a pic of one of these a while back and it was the only one i have ever seen for these year models. that persons badges had "crew cab" above "special".
also lostinfords, thank you i figureed out what it was with my heater. believe it or not there was just a lot of grime built up between the water tubes/fins on the heater core. i disconnected it and soaked it in engine cleaner and then washed it real good and it works fone now. the dirt was mostly on the backside where i couldnt see it from inside the cab looking up into the heater box.
  #416 (permalink)
Old 12-09-2008, 12:50 AM
masterbeavis's Avatar
masterbeavis masterbeavis is offline
masterbeavis has a very good reputation on FTE. masterbeavis has a very good reputation on FTE. masterbeavis has a very good reputation on FTE.
This is the only thing I have seen.
As far as speakers are concerned, the only thing I would put in or around the roof area, are tweeters, with a potentiometer (volume knob) in case they are too bright. I like component speakers, separate woofer, midgrange/tweeter. A 50W RMS 4 channel amp driving them, good sound insolation, and a nice sub will make a pretty dang good sounding stereo system.
You can shoe horn speakers in the rear cab corner like I did. Yea, its a standard cab, but the cab corners are the same, and you dont have to cut your doors for sound. Midranges you can put in the center B pillar? Careful planning, and cutting, no mistakes! Once you make a cut, you are stuck with it.
__________________
Tony
Quando omni flunkus moritati - when all else fails, play dead.
If I posted something useful, click the http://images.ford-trucks.com/forums...reputation.gif in that post.
  #417 (permalink)
Old 12-09-2008, 04:22 AM
cool, glad to hear it!
  #418 (permalink)
Old 12-09-2008, 01:22 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Quote:
No need ot cut the doors - they already have holes in the for speakers
Also - you'd rather cut your cab than doors? Doors are easier to replace
And last - you aren't stuck with a cut in metal. That is the beauty of metal - it's much easier to fix than wood. Just a little welding, sanding and painting and you're back at square 1.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #419 (permalink)
Old 12-09-2008, 03:28 PM
Quote:
Honestly I don't remember. I pulled the badges off the truck shortly after I got it and that was almost 10 years ago. I know they are in a box somewhere. I pulled them off as they were falling off and I knew they would be hard to find.
__________________
  #420 (permalink)
Old 12-09-2008, 03:40 PM
IowaHighBoy's Avatar
IowaHighBoy IowaHighBoy is offline
IowaHighBoy is starting off with a positive reputation.
Heater Core making noise?
Will my heater core make noise if it is clogged or has its flow restricted. I am trying to find a noise that I thought was the fan but I am quite sure not that it is not.
Also I need a window requlator for the drivers side. Should I just buy new or does some one have a good one around?
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
