I was actually going to go to the fabric store and do the same thing w/ the crew as I did w/ the s/c, it held up quite well, although I may try to replicate a lariat style headliner, I just picked one up for a s/c. did you notice that I added the mid mount interior light? It seemed to have taken out what may have been a 'sagging issue' down the line, I also plan on doing that in the crew cab, there were so many times that I neede those map lights. first I have to fill in the sun roof cut out, I actually cut the unrusted portion of roof off a '78 f350 2wd crew cab that I have for parts.
My other option is to do the trim in polished aluminum, I did a set up for my deck hatches in my boat ...that came out aweet! Maybe it would look good as headliner trim... but that is way down the line, I have to get the new...older, but in pristine shape, cab on the chassis.
I did notice the light. This location isn't very feasible in a crew though as the light would have nothing to mount to. The "map" lights you mention would work if you mount them to that center support.
As for the trim - polished aluminum would look good (I think the XLT trucks all had chrome. My 76 crew did). I am planning on powdercoating mine black though.
__________________ Have you flown a ford lately? 1938 Ford Pickup = hot rod
1970 Ford F250 long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cabthread in "motor swap" forum 1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
Thanks for the headliner pix. That helped a lot. Next. Carpet, and Door and window rubber.
Speaking of carpet - I have a custom made carpet kit out of my 74 crew that I will make someone a heck of a deal on. I am going to rhino type liner inside the cab instead of carpet so I don't need it. I've run an add in the classifieds a few times with no luck and I can't bear to just throw this carpet kit away as it is specific to these old crews.
It is a bit dirty but could get cleaned up and would look ok. I'm sure it's better than what's in a lot of the trucks out there.
Can anyone here use it? You can PM me for pics - I've got a bunch. It is a custom made (seems to be molded to the floor) kit that was VERY nicely done. It's tan and I have brown floormats (front and rear) and dash cover thing that match it. I was shocked when looking at the price LMC wanted for a carpet kit for just a standard cab truck - I can let this thing go for WAAY less if it would help out another old crew fan
PM me for details.
dang these are good looking trucks! It looks like the Mutt's red cousin...
The early grills like that are by FAR my favorite on these trucks!
i found a company that says they make a headliner that will fit in a 1973-79 crew cab ford. i dont know if anyone has posted their name on here before but just in case. the name of the company is
WLS Headliners
and their website is
wlsheadliners.com
i have not seen the headliner myself but i emailed them and they said they have one that will work for these trucks. hope this might help somebody.
oh yeah, IowaHighBoy, your truck looks great. i hope i can make mine look that good.
or as close as i can because mine is a factory f-350 dually so i will try to build a nice flatbed for it. has anyone seen the ford super-cruser beds on the f450s and 550s, and if so do you think that type of bed would look good on one of these trucks if i use 73-79 ford bed sides?
The websites sells material that glues to you existing panels. I think most of us need the panel. I did not see that on their website. If someone sees it let me know.
Quote:
WLS Headliners
wlsheadliners.com
fficeffice" />>>
What do you think?>> >>
I could paint it gray to match the rest of the int. >> >>
Would the 4mm be skinny enough to fit under the side rails and would it still be durable enough to not sag if I made one solid panel.>>
That plastic stuff would probably work pretty well. I still think based on the contour of the inside of the roof you might need something to keep the middle up against that support rail.
For anyone close by - I have a rear headliner piece out of the truck that you can trace for a template if you don't have a stock one to work off of. Maybe I can take dimensions and draw it and save as a PDF for people if they want. It might be easier for people get a large piece of cardboard and make their own template in their own truck though.
I'm also open to parting with the stock rear headliner piece (it's been recovered) as I am making mine out of aluminum sheet.
Has anyone put speakers into the roof/headliner? My truck was stock no radio. I'd like to put in a system and would love to hear ideas about where to put the speakers.
Things to consider:
running the wires
speaker protection
monutability and safty (don't want one falling on my head at a quick stop)
I believe LMC makes a headliner like this for the standard cabs - do a search and you'll find some pics. Trying to make a back half match this headliner could be pretty difficult though.
i am suddenly having a problem with my heater in my truck. if it makes any difference it has a factory ac. when the truck is not moving the heater blows hot air out of the floor or defroster, whichver i set it on, but once the truck starts moving it blows cold air in from outside. does anyone know what is wrong with it and if so, how do i fix it? any help would be great because it is starting to get cold outside.
