Crewcab Only Thread.
#316
#317
Can't reply on the other forum Ron... Great insights.. I'm surprised at just how much of the 550 stuff you can use.. I didn't even think about wiper problems.. sounds like the laws of geometry will come into use for you ;-) I just love the idea that it will pretty much look like a classic crew on the outside, and feel, look, and drive like a 'new' truck on on the inside.. very cool indeed.
Did you seek out the 2001 generation truck on purpose, or is it just what became available? I honestly don't know the Ford years of bodystyle/drivetrain changes after about '96, and I don't know much about diesels either (I've heard there's one Ford diesel to be sure NOT to get... maybe it was a 6.0 or a 6.6 I think??). Compared to my '79 460 crew, My buddies '05 F250 diesel crew doesn't even seem to struggle when we use his truck to tow my trailer.. Torque!!
I ask all these q's because I love this project and what you're gaining by doing it (moving only the classic sheetmetal to the late model frame/drivetrain -instead of retrofitting the modern diesel drivetrain into a '70's frame and suspension), and I'd like to learn which parts and source diesel truck to keep an eye out for.. It's obviously a lot of work, but wow, what a truck when you're done!!
#318
The First link that I posted, I don't thing I copied the whole link. But the second seems to work. I'm on many sites, it was hard to decide which one to put the build on. I've had so much help from great people on all the great sites so I thank all of them and try to get the word out where they can keep up on the build.
I had a 99 F350 for years and loved the way it ran and rode. So when I started searching for a chassis I new it would be a Superduty chassis with a 7.3. When I found this one it had the 7.3 and a bonus of air ride suspension,the frame was junk. So I started looking for a good frame,found another 2x and got that. Was going to build a 2x but,what's a guy like me without a 4x, so I found a front axle for it and now I have a 01 f550 7.3 auto 4x4 with air suspension.
You have to understand that the F550 stuff doesn't work in the 76, It is made to work. I've been fabbing and creating things in wood and metal since I've been 10 years old. So there's not to may things I won't do or at least try. I don't have alot of specialty tools and expensive equipment, but I use the tools I do have to make do.
So when I get done with this thing, there will be different projects but there won't be a day that I drive by you on the road, that I won't wave and have a smile on my face from ear to ear.
Thanks Ron
Thanks Ron
#319
I have a 1977 f-250 crew cab shortbox 2wd (engine is a 500 caddy trans is 700r-4) guy should be shot for what he did but this truck has tons of pwoer bed is almost PERFECT rest of body is ALMOST PERFECT minor dings and scratches ARIZONA truck guy said he had 16k invested gave me reciepts its true although it does not quite look like a 16K truck although it is very nice and turns lots of heads willing to sell e-mail me @ fire_fighter_57@yahoo.com if you interested in the truck I also have a 1976 f-50 super cab short bed xlt ranger that is pretty slick too that is for sale 460 auto
#320
Hey guys.....my uncle wants to give me a '78 F350 crew cab....it has some rust issues, roof, bottom of doors jambs, and the rear door bottoms. My question is....I know they don't make any patch panels for the bottoms of the rear doors....but has anyone had any experience replacing the sheetmetal using a panel made for the front door by cutting them down to fit?
Or is there anywhere/anyone I can contact about obtaining some rust free roof doors?
Lenny
Lenny
#321
#323
Crew Cabs
I am restoring a 77 Crew-Hillbilly Limo is its name. I have done a complete body off resto. Powder coated the frame and the interior of the body, the firewall and even the bottom of the cab. The axle housings and everything that is bolted on. All the nuts and bolts have been bead blasted and powder coated. The cab and nose are just painted. I haven't posted new pics yet but will in the near future. I am running 33's for tires and they look good. 4X4 highboy with Dana 60 front and rear. I have been on this project for 2 years already. Hope to have it done by spring.
#324
#325
powdercoat
The reason everything is powdercoated is that I own a shop ith a 20 foot long oven. The powder is only about 3-4 mils thick and sockets or wrenches still work after the powder is cured. The threads are somthing that I touch up with some paint and a q-tip. I started this project wanting to see how far I could go with the powder coating. So a lot of it is a trial basis for me. I have more pics that I need to post.
#326
#327
OK crewcab guys, how many of you have taken rear doors from one truck cab and put them on a different cab? How did they fit? Did you have to do some major/ minor fabrication work to make them fit perfectly? Just wondering because someone told me each set of rear doors was "custom, hand-made for that cab". Just curious.
Thanks!
Thanks!
#328
Rear dooes
I had my cab off and sand blasted it. When you look at the bottom it is very obvious that each ab is going to be different. I had the rear doors all apart and they are not the same. If you change doors from one truck to another expaect to spen a lot of time on making them fit correctly. Good Luck
#329
